20 Most Recent DeLonghi Stiromeglio Compact PRO 300 Iron Questions & Answers
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
DeLonghi... | Answered on Aug 23, 2014
You have a short in the wiring inside of the iron. It will not work until you get the short fixed.
DeLonghi... | Answered on Oct 31, 2012
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
DeLonghi... | Answered on Jul 14, 2010
I would first try with household vinegar (empty as much water as possible) and if that doesn't work to free the valve, then something more aggressive containing acid like any of the Lime Away type of lime/rust removers. If it is still stuck, you may have to bet the iron hot to make the acid more effective. If using other than vinegar, I wouldn't advise allowing anyone to breath the vapors; do this in a utility room or basement.
That trigger probably acts on a needle valve that controls the flow of water to the point at which it is turned to steam and it may simply be too contaminated with lime buildup to slip back into the valve body.
DeLonghi... | Answered on Jan 11, 2010
DeLonghi Stiromeglio Compact PRO 300 Iron Logo
15 questions posted
Top DeLonghi Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
View Most Popular
DeLonghi Irons
  • DeLonghi Irons
Most Popular Question
am unable stop steam iron
  • Irons
