20 Most Recent Viking VGIQ5323RE1N Gas Grill Questions & Answers
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
2/24/2012 12:32:17 AM • Viking... • Answered on Feb 24, 2012
Viking grill connected to natural gas on 110v
If the grill has a NG regulator, try replacing it.
8/19/2011 8:10:47 PM • Viking... • Answered on Aug 19, 2011
Viking Grill
Remove the drip tray, the serial# tag is on the unit beneath the drip tray
3/20/2009 2:55:15 AM • Viking... • Answered on Mar 20, 2009
I have a Viking Grill model VGBQ530 with cast iron
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
8/2/2017 8:10:17 PM • Viking Grilling • Answered on Aug 02, 2017
Are there batteries in the old Viking grills? my ignitors are not working. it doesn't look like there are batteries
If the ignitors make a sharp snap or click when you press them, then you don't need batteries. Try to clean the tips of the ignitors (carefully). On the other hand, if the ignitor is an electrical pushbutton (often rubberized) that doesn't make the clacking sound, it's electric and needs batteries. Try to (gently) unscrew the pushbutton assembly . Grillmakers often hide the battery inside.
5/30/2015 12:22:03 AM • Viking Grilling • Answered on May 30, 2015
Have a Viking built in. Ignitor is working, fresh tank of gas, turned on valve on tank, grill will not light.
If you are using a 20# propane cylinder, most likely you have just turned the tank valve on too fast. There is an excess flow built into the hose fitting, so when you first turn it on to an empty line, the sudden surge of gas causes the valve to 'check' or close. Turn off the tank valve, disconnect the hose fitting from the tank valve and then re-hook it up again. Now very slowly open the tank valve until it's completely open and then try lighting it again. If this does not fix it, then make sure the hose fitting that attaches to the tank valve is tightened all the way, so that it pushes open the pressure seat inside the tank valve. If the hose is still loose or can still swivel, despite the adapter being tight, then your plastic adapter may be broken and is not tightening all the way onto the tank valve or your inner tank valve black rubber gasket is missing.
5/19/2015 10:31:39 PM • Viking Grilling • Answered on May 19, 2015
0answers
I cannot get propane to
Replace the regulator it is bad!
9/3/2011 1:27:19 PM • Viking Grilling • Answered on Sep 03, 2011
I cannot get a flame
Here's the problem and the solution. The new regulator you just installed, locked up when you turned ON new tank. This oocurs quite frequently with the fairly new OPD equipped grill tanks.
Solution:
1. Turn the gas tank's valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY, SLOWLY (slow motion, slow),
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH.
Did the burner light and does the flame height look correct? If so, light the remaining burners
the same way. Now, do all the flame heights look correct? If so, you solved the problem (with
a little help). Remember to ALWAYS open the tank valve very, very, slowly.
Happy Grilling!!
6/23/2011 5:53:02 PM • Viking Grilling • Answered on Jun 23, 2011
Viking gas grill - when
What you have described sounds like a clogged burner as well as the venturi valve on the burner. Your will need to remove the burner to clean it and the venturi valve on the open end of the burner, that goes over the burner orifice. Spiders like to build nest in them and clog them up. The venturi valve will look like two slots, cut in to each side of the burner, at the open end. It's function is to mix air with the gas, for proper combustion.
Hope this helped you to troubleshoot and solve the problem. Please let me know and Happy Grilling!!
6/16/2011 9:40:29 PM • Viking Grilling • Answered on Jun 16, 2011
Can not get grill to
Replace the Regulator to get gas running to the burners again
8/19/2010 6:04:01 PM • Viking Grilling • Answered on Aug 19, 2010
2answers
My smoker reads eaaf on he digital printout
I'm having the exact same problem this morning. It worked a few days ago when I "seasoned" it. I read something about the controller being cold sensitive so I brought it inside to see if that works.
12/4/2009 5:41:42 PM • Viking Grilling • Answered on Dec 04, 2009
Instructions for Antony Worrall Thompson Patriarch 3 Burner Gas BBQ with Side Burner
Where are the instructions
3/20/2024 1:41:40 PM • Grilling • Answered on Mar 20, 2024
4answers
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM • Grilling • Answered on Dec 27, 2023
3answers
Can I convert my glo warm GWRN18 natural gas heater to propane
glo-warm doesnt sell a conversion kit since they have propane version they sell the propane unit --their are universal conversion kits but you would need to check if their compatible to the glo warm unit
12/23/2023 9:55:32 PM • Grilling • Answered on Dec 23, 2023
How does my gas grill ignite
Unscrew the gas igniter button and insert the battery positive end upwards. Then screw the button cap back on. A tip, don't let it rain onto that button. Torrential rain stopped my igniter working for 6 months. Page 9 of your manual refers https://www.manualslib.com/manual/705964/Jenn-Air-720-0336.html?page=9#manual Parts https://www.appliancefactoryparts.com/gasgrillparts/jenn-air/720-0336.html ..
12/22/2023 4:57:25 PM • Grilling • Answered on Dec 22, 2023
Viking VGIQ5323RE1N Gas Grill Logo
7 questions posted
Top Viking Grilling Experts
Paul Carew
john h
Are you a Viking Grilling Expert? Answer questions, earn points and help others
View Most Popular
Viking Grilling
  • Viking Grilling
Most Popular Question
grill slow start doesn 39 t get hot
  • Grilling
