20 Most Recent
KitchenAid Superba KFRS361TSS Stainless Steel Propane Grill Questions & Answers
Icemaker not making ice in refrigerator.
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath the freezer needs to be0/4degrees to start if not that cold may need freonor compressor my be weak.
The ICE Maker just Stooped making Ice ? but the water is ok
I don't know about the dust bunnies on your coils, sounds like you would have you use a vaccum attacthment or even a compressed air nozzel, but as far as your ice maker goes try totaly turning off the fridge and compleatly 100% defrosting it.
Kitchenaid superba side by side refrigerator over temperature...
I think I may have the solution, after having suffered through the same problem for months. I have a Kenmore Elite side-by-side which is really the same as KitchenAid and Whirlpool. Having thought of complicated solutions first, I have finally gotten back to step 1, simple solution. Tape the switch on the top of the freezer compartment and see if that works for you. I believe the door while seemingly closed is not pushing the switch in far enough. If that works for you, you can probably glue something to the top of freezer door so it can push in the door switch a little better. The reason that it beeps is that the switch is not pushed in enough and the light is still on inside while the door is closed. The refrigerator then thinks the door is still open. I really hope this works for you as I can sympathize with you having listened to the beeps for months. I feel sorry for people who have changed one circuit board after another to no avail. And there are so many stupid repairmen out there offering dumb advices and perform needless repairs.
Preventing damage
Yes, check how much power your fridge uses i.e. AMPS/WATTS etc then get a surge protecter that can cope with that load. If you buy a guarenteed one and your fridge gets damaged, you will be able to claim.
Grill igniter not work
May be you need to replace the igniter. The igniter is easy to break if it is used for a long time or if it is not used for a long time. My grill also replaced the igniter and the burners in June, they are all rusted, i bought them at this online store and the quality is pretty good grillpartsreplacement.com/collections/kitchen-aid-720-0745b-gas-grill-replacement-parts-and-accessories
