20 Most Recent
LG VOYAGER VX10000 Cellular Phone Questions & Answers
Phone not ringing?
go to settings then phone settings then voice commands then call alert and put ring only
I cant find the ESN/DEC/HEX number on my LG
I had the same problem initially for the longest time, but I finally found the MEID number...I don't believe the Voyager has an ESN; I think it only has a MEID number. I also have the Voyager, and I am trying to switch from the phone I'm currently using to my Voyager (my other one broke.) But the MEID number is on the inside of the phone, where you place the battery/back cover. It should be on the sticker that says "MODEL NO" on top. And right below where it says "MADE IN KOREA," it should read "H/W REV : 1. 0" unless your number is different. Right below that it should read "MEID : ," with the 14 digit number; I hope this helped!
Lost pictures on LG Voyager
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Touchscreen has lines through it that come & go
You are experiencing an intermittent failure. It may be physical in nature. Do not stress the phone mechanically. Do not keep it in your rear pocket, do not put pressure on it. Do not drop it.
LG Voyager, Music won't play.
Play music files - LG enV: At the main screen, press OK to select Menu. Select Get It Now, then press OK. Select Music & Tones, then press OK. Select My Music, then press OK. Select Songs, then press OK. Select the desired song, then press OK to select Play.
Contact Name Doesn't Show Up
If only one number is not showing on your screen it means that you have blocked it with your application or messaging system that you'll need to take the number out of the blocking list. But if this doesn't help you the number itself might have a privacy feature that you cannot see the number itself but just showing private number.
I need to unlock the
to unlock your phone lock(security lock) you need to reset your phone. if you need to unlock your phone from network provider you can try codes. its the safe way to
unlock your phone. because when you unlock your phone through software
or hardware there are possibilities for data getting corrupted or lost.
but there is no such possibilities when you unlock through codes. thats y
i prefer this method to unlock my phone. i got the codes from this site
Superunlockcodes.com to unlock my phone.
What if u found a phone that has been reported
Your question is what if I found a phone that was reported lost...I would return it. That is why Verizon put's measures in place to block accounts from allowing people to activate phones that have been reported lost or stolen. Put yourself in the place of the person that rightfully purchased the phone and has either misplaced the phone or had it stolen. Would you want someone to return the phone or would you want them to try to work around the system to try to activate the phone that they already know is lost or stolen. By knowing the phone is lost and having the ability to return it and purposely not doing so, you are stealing the phone. Since Verizon has the MEID number on the back of the phone, they can return it to the rightful owner if you give it to them. If it were me, I would give it to Verizon and do the right thing.
I cant find headphones that fit in my phone?
Try to contact the vendor for genuine headphones, is your cell phone have bluetooth connection? if any just use bluetooth that have universal connector. so you could use any headphones you want.. hopefully it works..
Pics from LG Voyager to computer
I just send myself a picture text message, and put my email address in where the cell number of the receiver would normally go. Then I pickup my emails on my PC and save the pics.
I have a data cable, I just never use it. LOL
