20 Most Recent
Viking DDBB363 Bottom Freezer Refrigerator Questions & Answers
Beeping noise
try shutting the power off to the unit, tere is an on/off switch behind the top grill. It will reset the control board.
I have a side by side Viking refrigerator and
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed.
Faulty Switch.
Regards
Advisor
Lights are off how can i reset them
To further assist the previous answer, if door left open long enough it auto shuts off as those lights generate hi heat . Turn main power switch off then on to reset.
