20 Most Recent ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Questions & Answers
3answers
Can i put nVIDIA geforce 8600 on my p5sd2-vm
Yes, your Asus motherboard will support the Nvidia GeForce 8600 PCI-Express graphics card.
However one thing you should consider. The 8600 card is SLI compatible but the motherboard only has one PCI-E x16 slot.
You will also need to make some changes in your bios.
In order to help you configure your system for a PCI-E graphics follow these steps.
1. Uninstall your current display driver software through windows control panel. Windows may ask you to restart your system, do not restart. Shut windows down which will shut off the system.
2. Unplug the power cable from the system & open your case.
3. Install your 8600 card. (Double check it is installed correctly & if needed has the extra power cord connected to the card.
4. Re-connect the power cord.
5. During boot up enter the bios by pressing the Delete key every couple seconds.
6. Once in the bios click the Advanced tab, see top of page 2-19 in your manual.
7. Than open Onboard Device Configuration
Open North Bridge Configuration, see page 2-22
Change Primary Graphics Adapter to [PCI-E]
Change Internal VGA to [Disable]
Change Share Memory Size to [Disable]
8. Save Bios changes & exit. Your system will auto restart.
Once windows has finished loading install the 8600 driver software & directX 10.0. You can also go to nVidia & download the latest software driver @
http://www.nvidia.com/Download/index.aspx?lang=en-us
Thanks for using FixYa!
Mike
8/28/2022 9:57:26 AM • ASUS COMPUTER... • Answered on Aug 28, 2022
2answers
ASUS P5SD2-VM GRAHICS PROBLEM
Have you received the latest flash for the board. Could need the bios update so go to the website asus.com and find your board and flash it with the latest update.
Thanks John C.
12/24/2019 9:58:01 AM • ASUS COMPUTER... • Answered on Dec 24, 2019
Asus mbd p5sd2-vm drivers for win7 32 bit
Go here https://www.asus.com/Motherboards/P5SD2VM/HelpDesk_Download/.Open Driver & Utility choose vista drivers if you are using windows 7 so you can update the sound and onboard vga drivers
4/19/2018 12:34:15 PM • ASUS COMPUTER... • Answered on Apr 19, 2018
2answers
I am using windows 7
If your board isn't supported you won't be able to find drivers. You will need to upgrade your motherboard.
1/14/2017 4:21:12 PM • ASUS COMPUTER... • Answered on Jan 14, 2017
3answers
How to activate Windows 7 Ultimate 32 bit?
if you need genuine key or else you want to learn something about windows you can click here, many software you can find here, absolutely suit for computer www.fastbackorders.com
12/4/2015 8:24:16 AM • ASUS COMPUTER... • Answered on Dec 04, 2015
I have a pioneer amp ax700. The right hand speaker is very distorted but everything else works well. Do you know what the issue might be?
possibly a loose connection inside the amp check the connections on the board
5/29/2014 4:40:52 AM • ASUS COMPUTER... • Answered on May 29, 2014
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3. which vga driver do i need to install.
if you have a video card use it if not motherboard if it has one i like video card myself
5/25/2014 4:18:59 PM • ASUS COMPUTER... • Answered on May 25, 2014
Sis motherboard 968 sound driver
go to asus web site support download there ok
11/10/2013 5:49:32 AM • ASUS COMPUTER... • Answered on Nov 10, 2013
0answers
Audio drivers
5/1/2013 4:27:30 PM • ASUS COMPUTER... • Answered on May 01, 2013
Drivers xp
5/1/2013 4:25:19 PM • ASUS COMPUTER... • Answered on May 01, 2013
3answers
Vga driver is not working properly
i have asus P5SD2-VM sis672/sis968 mother board.
but my graphic card driver is not working properly , when i download any game which is of having graphic card(128mb) min requirement it does not work properly.
what should i do for this .
3/2/2013 12:46:40 AM • ASUS COMPUTER... • Answered on Mar 02, 2013
I want to that sis968 rtm876660 kae sare driver diye jaye
Hello try this site:http://www.asus.com/Motherboards/Intel_Socket_775/P5SD2VM/#downloadPlease select your windows system.Open the driver folder and click on global for download.Unzip the file before you install the driver.If the drivers site is wrong visit the manufacture of the pc`s site.Or reply me back with name (manufacture) and number of the mainboard.This is important when to find the right drivers for you.Good luck
12/15/2012 2:17:30 PM • ASUS COMPUTER... • Answered on Dec 15, 2012
2answers
Sound card free download
You cant download a sound you can download sound card drivers.
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free also http://download.cnet.com/2000-20_4.html
Just type in what you want or need be specific you might have to try a few times to get it right.
Tick in either the all software or the windows software box.
IE: motherboard name sound drivers
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
hope it helps
11/15/2012 10:03:14 PM • ASUS COMPUTER... • Answered on Nov 15, 2012
ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard Logo
273 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus p5sd2 vm multimedia audio
  • Computers & Internet
