20 Most Recent Carrier 38CKC036 Air Conditioner Questions & Answers
Can you give me an idea what code 34 represents?
Carrier 38CKC036... | Answered on Apr 03, 2019
WHAT SIZE FUSE ARE YOU USEING IN YOUR HOME IT COULD BE THAT YOU ARE CONNECTING TOO MANY UNITS
AND MAYBE YOUR FUSE CAN'T HANDLE THE LOAD.
Carrier 38CKC036... | Answered on Feb 05, 2018
bad fan motor or compressor
Carrier 38CKC036... | Answered on Dec 03, 2017
Sounds like whoever did the txv, changed the fan speed. Yes, the fan speed is adjustable. Some HVAC units can have up to 4 speeds on the motor. Low, Med Low, Med Hi, and Hi. this is so the same unit can be used for several different cooling coils and tonage. The faster the speed in the cooling mode, the less cool the air will be.
Carrier 38CKC036... | Answered on Sep 29, 2017
No that is not the solution, it the capacitor were bad, then it wouldn't start manually.
You need to be looking elsewhere. The problem may be in the refrigerant level. Those units are supposed to have pressure switches.
Check elsewhere such as pressure switches and make sure the thermostat is working properly.
Go to the thermostat and jump out R to Y. If the unit comes on, your thermostat is the problem.
Carrier 38CKC036... | Answered on Jul 22, 2015
Plugged filter...plugged indoor coil.
Carrier 38CKC036... | Answered on Apr 21, 2015
Very possible the long bladed fan is stuck. Possibly when filters were cleaned and replaced, a part is touching the blade. Remov filters and turn blade by hand. Does it move freely.(make sure unit is off when turning the blade.
Carrier 38CKC036... | Answered on Mar 03, 2015
There's no polarity, it's AC voltage.
Carrier 38CKC036... | Answered on Dec 18, 2014
change the capacitor. also check to see if the right amount of volts are getting to the unit. look at the contact and put your meter on the appropiate sides and see if its 220-240. if it is, good, then change your capacitor. If not, then stop and call someone who knows what they re doing with electricity. its supposed to get 220-240. if its only getting 110 or so, then your electric co. has a problem. you might want to let it set for a while and try to turn it back on and see eaht happens.......... aint no pro but had the same problems..............
Carrier 38CKC036... | Answered on Nov 21, 2014
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
Carrier 38CKC036... | Answered on Oct 14, 2014
Noise is produced by the fan and the compressor. If it's always made this noise then it's OK. Capacitor simply gives the fan and compressor a high voltage impulse to start them. Has it always made this noise? Something inside could have shaken lose, the fan is unbalanced, etc.
Carrier 38CKC036... | Answered on Aug 16, 2014
Capacitors are rated uf and voltage (35uf 5uf 370 volt) should be right for your unit but the size will be on the old capacitor.
Carrier 38CKC036... | Answered on Aug 12, 2014
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Carrier 38CKC036... | Answered on Jul 15, 2014
The serial number is needed to answer this question
Carrier 38CKC036... | Answered on Jul 06, 2014
description: cooling fail action is activated. Action: check compressor operation. turn off main power-restart the unit.
see more: Air Conditioning Fault Codes
Carrier 38CKC036... | Answered on Jun 30, 2014
Carrier 38CKC036 Air Conditioner Logo
366 questions posted
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Heating & Cooling
Most Popular Question
cf code error carrier
  • Heating & Cooling
