20 Most Recent
Siemens WFXD5202UC Washer Questions & Answers
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
11/20/2013 7:14:22 AM •
Siemens...
Answered
on Nov 20, 2013
Ssssssssssss
Unfortunatley this is an error code & your main computer has failed & needs to be replaced.
2/21/2011 11:49:21 PM •
Siemens...
Answered
on Feb 21, 2011
End-of-Cycle Signal is turned off.
Welcome to FixYa.
You should be able to select the desired volume for the cycle signal.
Here`s how...
1) Press the Menu button to scroll through options to "Signal setup".
2) While in "Signal setup", press and hold the Select button to continuously change the signal volume.
3) While changing the volume continuously, the display will show "Continuous" – when the maximum volume has been reached, the display will show "Max".
Hope that answer`s your question. Let me know if you require further assistance.
Please take a moment to rate the info provided here today.
Good luck.
macmarkus :)
8/26/2010 3:39:04 PM •
Siemens...
Answered
on Aug 26, 2010
Washing machine Siemens IQ800 - clear error
The
E34 error code on your Siemens IQ800 washing machine indicates a
door locking problem. Let's troubleshoot this issue step by step:
- Close the Door Properly:
- Ensure that the door isfully closeduntil you hear aclick. Sometimes, anexcessive loadof laundry can prevent the door from closing correctly.
- Check if there's any garment trapped between the door and the frame. Remove it if necessary.
- Restart the Program:
- After ensuring the door is properly closed,restart the washing machine program.
- If the error persists, proceed to the next steps.
- Check for Door Lock Issues:
- Verify that thedoor lock mechanismis functioning correctly.
- Inspect thedoor insurance wiringto ensure there are no loose connections.
- Look for any blockage or issues with thetriac doorin the control module.
Siemens a12-26 drawer cleaning
- Locate the tab on the softener compartment and lift it.
- Pull out the dispenser drawer by gently pulling it towards you.
- On the top of the dispenser drawer, you should see a locking mechanism. This mechanism is usually a small lever or button that you need to press in order to release the lock and allow the drawer to be removed.
- If you can't find the lever or button, consult the user manual for your specific model of washing machine, which should have instructions on how to remove the dispenser drawer.
- Once the dispenser drawer is removed, you can clean it and the interior of the machine.
Note: If you are unable to find the instructions in the user manual, you can also contact the manufacturer for assistance.
My Siemens IQ700 washing machine does not work
mens IQ700 Washing Machine Not Working.
Tell me Answer My Siemens IQ700 washing machine does not work
There could be many reasons why your Siemens IQ700 washing machine is not working. Some common issues include a lack of power, a malfunctioning door lock, or a faulty control module. Without more information about the specific problem, it is difficult to provide a definitive answer. I would recommend checking the user manual or contacting Siemens customer support for troubleshooting assistance.
