20 Most Recent
Roper RTW4305S Top Load Washer / Dryer Questions & Answers
Washer walk around during spin cycle but is level
Sorry to say this BUT I yhink that following the guidance notes below should help!
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
I have a Roper washing machine. Is it normal that she keeps the same water to rinse?
No, it should pump out and add fresh water, agitate, spin, add water again, agitate, and then pump out for final spin. Check the pump and filter area for obstructions. Having said that, the logic board should halt everything and error out if there is no pump out. Try disconnecting from the wall socket for 15 minutes, and then plug back in.
My Roper top loading washing machine goes thru the first wash cycle, empties the water then stops. It does not move on to the rinse cycle.
If your Roper top loading washing machine is stuck on the first wash cycle, you're not alone! It's a common problem that can be caused by a few different things. First, check to make sure the lid is closed properly. If it is, then you may need to check the timer, the water level switch, or the motor. If you're not sure how to do this, it's best to call a professional. Trying to fix it yourself could end up costing you more in the long run. But don't worry, you'll be back to washing your clothes in no time! Just remember, when it comes to washing machines, it's better to be safe than sorry.
ROPER WASHER PULLEY SYSTEM WON'T SPIN OR DRAIN
There are a few potential causes for your Roper washer not spinning or draining:
- Drive belt: If the drive belt is broken or slipping, it could prevent the tub from spinning. Check the belt for any signs of damage or wear, and make sure it is properly tensioned.
- Lid switch: Even though you said the lid switch is ok, it's still worth checking it again as it is responsible for ensuring that the washer will not spin or drain unless the lid is closed.
- Motor coupler: The motor coupler connects the motor to the transmission and can wear out over time. If it has failed, the washer won't spin or agitate. Check the coupler for any signs of wear or damage.
- Drain pump: A clogged drain pump or pump motor failure can prevent the washer from draining. Check the pump and clean out any debris that may be blocking it.
- Control board: The control board could also be a potential culprit, especially if the washer is not completing cycles correctly. Check the board for any signs of damage or malfunction.
- Transmission: If none of the above solutions work, there may be an issue with the transmission. This will require a professional repair.
I hope this helps you diagnose and fix the issue with your Roper washer.
There are a few things you can try if your Roper washer is not going through the full cycle because it is only filling with a small amount of water:
- Check the supply of water: Check to see that all of the water supply valves are open and that the hoses are free of kinks and obstructions. The washer may slowly fill due to low water pressure.
- Check the valve at the inlet: The washer may not properly fill due to a clogged or damaged inlet valve. The valve may need to be replaced in this scenario.
- Verify the pressure switch by: The pressure switch tells the control board to move the cycle forward by sensing the tub's water level. It's possible that the control board won't be notified to start the next cycle if the pressure switch is broken.
- Examine the control panel: The control board may be defective and need to be replaced if none of the aforementioned steps resolve the issue.
Troubeshooting Roper Washing machine
Humming is normally indicative of a failed Start/Run Capacitor, but the fact you get nothing from it, leads me to believe it is a control board issue as well. Due the cost, call for Service so that you get the correct diagnosis.
