20 Most Recent
Oasis FreshStart 80 oz 10-Cup Coffee Maker Questions & Answers
I have a Fresh Start Oasis model fstb-p60-100
There is probably a scale deposit around the tank outlet that leads to the sprayhead. Unplus the macine from the wall. Remove the top cover. Pull on the black rubber connector that leads to the sprayhead until it comes off. Insert a Bunn Deliming spring into the black rubber connector and feed it into the tank, run it back and forth several times. Remove the deliming spring and reconnect the black rubber connector. make sure it is on all the way around. Replace top cover. Pour in a pot of water. you should get an instantaneous flow of water from the brew basket.
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Parts manual
here you go
http://www.oasis.ie/spares.php?product_id=29&menu_id=
please leave feedback
Thanks
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
