20 Most Recent KitchenAid RRK150 Stand Mixer Questions & Answers
Conversion 110v to 220v
Hello there, We do provide a conversion kit to assist you with your job. Please see below the link for your perusal: KSM150CONVUK KitchenAid Conversion Kit for KSM150 to 220v/230v/240v with UK Plug https://secure.kaparts.co.uk/sku/KSM150CONVUK
10/9/2019 9:20:16 AM • KitchenAid... • Answered on Oct 09, 2019
2answers
Kitchen Aid RRK150 only runs
Hi and welcome to FixYa, I am Kelly,
This is caused by either the speed control switch, the motor control plate or the motor. At the moment I really think it is either the speed control switch or associated wiring. This service manual is not and exact match for the RRK150 but the internal motor control parts are in the the same locations and the troubleshooting procedures are the same:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
And the bigger model service manual with nice to know info:
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Motor and motor control tests start on page 14 of the first link.
Also make note of the spring for the speed control in figure 50 page 18.
Thanks for choosing FixYa,
Kelly
3/24/2011 10:44:34 PM • KitchenAid... • Answered on Mar 24, 2011
0answers
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
3/30/2010 5:11:54 PM • KitchenAid... • Answered on Mar 30, 2010
My KitchenAid RRK150 325 Watts Stand Mixer started
It sounds like your problem will be in the back of the mixer then. Take the back cover off and have a look inside. Usually an electrical smell is also accompanied by sparks when the mixer is turning and often blackening of the area where the sparks are occurring. As the turning motor makes physical contact with the control plate I would investigate the area at the back of the motor. It may be that a new control plate is required.
1/26/2010 7:10:07 AM • KitchenAid... • Answered on Jan 26, 2010
My wife droped her kitchen aid mixer RRD150 now it
could be motor displacement from brushes to armature
estimate cost $39.-$59.00
4-5day repair time
ship USPS it's very inexpensive
11/23/2009 9:01:57 PM • KitchenAid... • Answered on Nov 23, 2009
2answers
How do I Open Up a KitchenAid RRK150 Mixer?
you have to take the pin out from right above where you put the beaters on, and then you can tap the circle part off, and get into the inside...
8/10/2009 6:40:26 AM • KitchenAid... • Answered on Aug 10, 2009
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears. https://www.google.com/search?q=olympus+s924+manual A Moulinex Coffee Mill might be a better solution for grinding wheat. ..
4/16/2023 11:16:47 PM • KitchenAid Food... • Answered on Apr 16, 2023
New Artisan Kitchenaid mixer KSM150 out of the box, head won't lock.
Don't forget if it is new it is under manufacturer warranty. Make the beater isn't too low and fouling, because the bowl is set too high? Try to lock with no beater.
3/25/2023 5:11:48 AM • KitchenAid Food... • Answered on Mar 25, 2023
3answers
Trying to adjust the beater to bowl clearance on my bowl lift KitchenAid K5SS. Mine has only pairs of screws, unlike manual diagram
Possibly one screw for up and one for down, working on a see-saw mechanism.
2/6/2023 9:52:44 PM • KitchenAid Food... • Answered on Feb 06, 2023
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
2/5/2023 12:30:16 PM • KitchenAid Food... • Answered on Feb 05, 2023
Kitchenaid Professional 6 Quart Mixer. The speed lever is stuck.
Question edited for clarity. Question moved to category. The speed lever is electronic. Videos and the part in the link. https://www.google.com/search?q=Kitchenaid+Professional+6+mixer+speed+lever+stuck ..
12/19/2022 12:42:07 AM • KitchenAid Food... • Answered on Dec 19, 2022
3answers
Kitchenaid mixer repair manual
google kv25g0xwh manual
7/30/2022 5:31:02 AM • KitchenAid Food... • Answered on Jul 30, 2022
2answers
How am I to disassemble my KitchenAid 7 speed hand mixer?
Try this video although '7 Speed' isn't an Alpha Numeric model number :>) https://www.google.com/search?q=disassemble+my+KitchenAid+7+speed+hand+mixer ..
7/30/2022 5:20:45 AM • KitchenAid Food... • Answered on Jul 30, 2022
Can i use it to make panko?
Panko are made with a special non-fermented bread that has no crust. You can however make good breadcrumbs with old hard bread and if you want it to be like Panko, pulse it and leave the crumbs coarse. I am a trade chef and use Panko a lot. Panko (???) is a type of flaky bread crumbs used in Japanese cuisine as a crunchy coating for fried foods, such as tonkatsu. Panko is made from bread baked by electrical current, which yields a bread without a crust, and then grinding the bread to create fine slivers of crumb.[1] It has a crisper, airier texture than most types of breading found in Western cuisine and maintains its texture baked or deep fried, resulting in a lighter coating.[2] Outside Japan, its use is becoming more popular in both Asian and non-Asian dishes. It is often used on seafood and is often available in Asian markets, speciality stores, and, increasingly, in many large supermarkets. Panko is produced worldwide, particularly in Asian countries, including Japan, Korea, Malaysia, Thailand, China, and Vietnam.
2/26/2022 5:54:01 PM • KitchenAid Food... • Answered on Feb 26, 2022
KitchenAid RRK150 Stand Mixer Logo
12 questions posted
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
kitchen aid rrk150 only runs
  • Food Mixers
