20 Most Recent
GE Spacemaker JVM1540 Microwave Oven Questions & Answers
JVM2070SK02
if you check it by putting the leads from a multi-tester and check continuity if this is okay replace the high frequency diode
1540 no turn no heat
There is a fuse and it may be some other things.But if you don't feel good about doing this kind of repair, I would have it serviced.
Why does it come on by itself
HOPEFULLY this only happens when the door is closed, or else you have a very dangerous situation. If it ever turns ON with the door open, unplug it IMMEDIATELY, and do NOT plug it back in. Microwave energy will damage human tissue with very bad long-term problems... it's not something to be taken lightly.
Otherwise, this sounds very much like the micro-controller in the timer/control module has had a serious failure. If this unit is more than 12 months old, it is past the manufacturers warranty period, and unless you purchased an extended warranty, it's likely beyond "financially advisable" repair.
If you have a friend in the electronics repair business, it may be reasonable, but I would estimate the replacement timer/control module would cost around $85 to $100, and about $70 labor to replace it.
Touchpad doesn't work on ge model #jvm1540sn1ss
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number
WB56X10826
from the Pros
here for
$114.62
plus shipping (that compares to
$166.50
from GE!)
You can also find helpful exploded view diagrams at that link.
At
our Web site, we have a video available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then disconnect your keypad strip as shown in the photo
below, then remove the screws that hold your circuit board in the old
frame.
Then carefully (since the display is made of glass) move your
circuit board to the new frame, and reassembly is the reverse of
disassembly.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
