20 Most Recent
Tilia FoodSaver V2240 Questions & Answers
Foodsaver pro locked up.
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
My V3820 foodsaver stop/seal light is constantly
Thanks, Lee Eismann. This was very helpful. I was about to purchase marine silicone as you suggested (washing and drying the sealing gaskets did not solve the problem for this time, which it did several months ago when this problem occurred) when I realized I had can a spray silicone that I keep like WD-40 to lubricate moving parts when they squeak. I sprayed this on both sides of both gaskets as well as the sealing roller and it immediately solved the problem. This tip should be in the owner's manual as it's clearly a very common problem.
