20 Most Recent
Regal Lager Phil & Teds Sport Buggy Single Storm Cover Stroller Questions & Answers
Our wheel is bulging on our Phil and Teds sport
phil n ted tubes sadly are not covered by warranty my pram had all 4 tires do it including the new ones they said there was a batched of shonky tubes and sent me new ones as i kicked up a stink as it was only a few months old, but it did it again when we had a heat wave :( why not try buying a new tube and tire from a bike store the ones phil n ted supply are dodgy! and deflating it and puting the tire back on the rim wont work cos they tube seems to just buldge again when walking and pope the tire off and come off the rim. hope this helps its a well knowen problem that phil n ted couldnt be bothered fixing.
Phil and teds sport stroller
melt some candle wax into the hole and put a drawing pin in it so its level and it spins easily without getting stuck
Can you take the cover off on a phil & teds
Yes, You need a philips screw driver for the lower basket. You will have to remove the push bar handle by depressing the metallic plugs that sit below the fabric seat. There is one on each side? Once you unsnap all the snaps, even from the carriage frame, the fabric will just pull right off.
