20 Most Recent
Dakota Watch Company Radio Controlled Watch, & Bezel, Plastic Strap Questions & Answers
How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
How do i change the hour?
I think you are changing from DST (daylight saving time) to local mean time.
Presumeably your problem is that the watch is not telling you the local time.
As the watch is radio controlled you can only change the time by choosing the location setting, so that the watch knows where you are.
Press the "mode" button to select the location abreviation and use other buttons to change to your local city.
When you have set the location, press the mode button to return to normal operation.
My national geographic radio sontrolled
Take out the workings,physically move all hands to 12 then insert battery and reasssemble. When the watch starts it does so at 12 o clock so the hands and digital display are synchronised. When it picks up a time signal to the zone it is set at they will correct together.
Or
Wait till 00:00 and put the battery in.
Goodluck.
How do I rest the time for daylights savings
Given that it is truly a Radio Controlled watch, which it must be considering your description, it should reset itself tomorrow morning (November 1st). I would give it a day to change before becoming concerned. Again, your radio controlled watch should reset itself around 2 or 6 am on November 1st.
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
- Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
- Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
- Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
