20 Most Recent Relic Multifunction Watch Questions & Answers
0answers
What battery is used in the watch
Take it to a watch shop, they should be able to replace the battery for you.
1/26/2010 8:43:46 AM • Relic... • Answered on Jan 26, 2010
2answers
Moisture in the face plate
You HAVE to bring your watch to watch repair shop as the moisture in watch can dissapear for an eye, but it will still there and can affect your watch to function properly.
Do not try to dry out watch yourself as the temperature changes can affect the watch as well.
Find your nearest watch repair shop as quick as you can because that moisture is shortening your watch life very quickly.
Don't forget to rate, please.
11/19/2009 8:10:32 AM • Relic... • Answered on Nov 19, 2009
The crystal is cracked in my Relic mens
Problably not something you should tackle by yourself. I replace them and have experience. You would need to make measurements and order from a place that has inventory. Then you would need to remove case back and movement. Then you would push out the crystal from the inside. The new crystal needs to be installed with the proper "glue". This also needs to be ordered. I suggest you take it to a local watchmaker that knows how to do this. But, best of luck
11/19/2009 8:03:23 AM • Relic... • Answered on Nov 19, 2009
Does not run. does this watch have a battery in
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
11/13/2009 4:22:29 AM • Relic... • Answered on Nov 13, 2009
What replacement battery is needed for a Relic Wet ZR15352250206
From my research, the Relic uses an SR920SW.
1/1/2024 8:02:45 AM • Relic Watches • Answered on Jan 01, 2024
How to set the 24 hr time on a women's relic multifunction Zr15992
What company made this watch? The only watch I can find with that name is not a digital watch so the 24 hour display does not possibly apply. Are you referring to the date display not changing at midnight? A quick trick that might work is to Roll the 12 hour dial forward 12 hours, (example 12 noon forward to 12 midnight). The dual time display is for when people are using two different world time zones. For example, for people who work regularly in two different countries. Using it means you don't have to keep reseting your watch when you change countries.
7/19/2023 6:20:26 AM • Relic Watches • Answered on Jul 19, 2023
2answers
I have a relic brand watch model ZR11957 and can't get the back to attach properly after changing battery, how do I fix it?
Did you use a small blade and pry between the back and a small indentation on the rim of the watch to pop it off? If so, its a pressure fit. There should be a rubber gasket around the back, make sure its there and in good shape. Place the watch face down on a pad similar to a rubber computer mouse pad, properly align the case slot with the crown stem and place into position, using both thumbs push down on the back, it should snap into place.
4/30/2022 1:04:16 AM • Relic Watches • Answered on Apr 30, 2022
2answers
What size battery do a relic zr11787
Take your Relic watch to a jeweler who will identify the type (not size) and may replace it.
8/7/2021 12:52:32 AM • Relic Watches • Answered on Aug 07, 2021
How do I replace the backing of A woman's Relic watch
Take your watch to a jeweler for a demonstration.
8/3/2021 7:24:53 AM • Relic Watches • Answered on Aug 03, 2021
Relic Multifunction Watch Logo
16 questions posted
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
View Most Popular
Relic Watches
  • Relic Watches
Most Popular Question
moisture in face plate
  • Watches
