20 Most Recent
Quinny Buzz 3 Sulphur Jogger Questions & Answers
Hi, what is the difference
Hi
For Quinny Buzz 2007-2010 model there are two seat fabrics. The infant stage seat fabric is a thicker, neoprene fabric for newborn babies up to approximately 18 months old. The 2nd stage seat fabric is a thick canvas type fabric which replaces the neoprene fabric and provides more space for an older child (approx 18 months to approx 3.5 yrs) Please contact us directly if you require additional assistance -
Dorel UK Customer Service
What is the difference between
Good Morning
The 2007 model came with a single thick seat fabric which customer feedback indicated became too small for older children, so the 2nd stage seat fabric was introduced and all Buzz models between 2007-2010 have two seat fabrics depending on the age and size of the child using it. The 2011 model has a single seat fabric suitable from birth right up until about 3.5 years of age.
In addition improvements have been made on the chassis overall as with any new product each time a new updated version is released but the basic chassis structure remains the same and spare parts are interchangeable to an extent.
The 2007-2010 models would have come with the Buzz box as standard, and the Buzz shopping basket was a seperate accessory: For the 2011 model the Buzz shopping basket comes as standard (Customer feedback indicated it would be more popular and useful) and the Buzz box is a seperate accessory.
I need quinny buzz3 bumper bar
CONTACT QUINNYSALES ON 07886531199 THEY REPAIR THE BUZZ HANDLES (CABLES) ALLSO SUPPLY FOAM GRIPS AND BUMPER FOAM / BARS
I sold my Quinny Buzz
Good Afternoon
Are you in the UK? If so please contact our customer service team at
[email protected] for us to provide assistance.
If you're not in the UK please visit
www.quinny.com and select the country you're in, then go to the "Contact Us" tab to get in touch with the customer care department in your area.
One of my tires on my quinny buzz keeps going flat
Yes there is an inner tube which sounds as if it has a puncture. I bought replacement inner tubes off e bay for mine when the same happened to mine. You can then either take the tyre off yourself and replace the tube (bit fiddly unless you have a suitable tool like a strong screwdriver for releasing the tyre) or try taking it to your local bicycle shop who could no doubt remove and refit the tyre for you for a small fee.
The frame holding the handle has broken on my
You will need to get in touch with Dorel UK, they will replace the frame and give it a full service at the same time.You will need to send the stripped down frame to them via courier. If you can, ask a local Quinny supplier if they can send it back on your behalf. John Lewis did it for us.
Puncture back wheel
you take the wheel off by pushing in a button at the side of the wheel on the inside, it is a quick release wheel and it simply clicks back in when it's been repaired. hope this helps!!
Hi, I have a Quinny Buzz pram that has an
HI,
This sounds like you need a replacement gas cylinder. This is not something that you can do yourself and would need to be undertaken by a qualified person. You need to contact either your retailier or
www.dorel.co.uk
I hope this helps.
Looking to change from quinny buzz 4 to a quinny
You can buy all the types of buzz wheels (front 3 wheel unit, front 4
wheel fork unit, front 3 all terrain air inflated unit and rear wheels)
direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel:
01842 763281., they are always super helpful and very nice. Or you can
buy them from this retailer (which I found to be a good deal cheaper)
http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or
on ebay which are definitely more expensive for new wheels, but perhaps
not for used ones. Hope this helps.
I dont know how to attach the sleeping bag to the
If you undo the shoulder pads on the straps, you will see a metal hook, undo this hook and you will then be able to slide these through the holes in the footmuff. If you are finding the straps a little too short, I would suggest that you contact
www.quinny.com who will be able to send you some harness extenders straps.
I hope this helps.
