20 Most Recent
Frigidaire Professional Series PHS68EJSB Stainless Steel Side by Side Refrigerator Questions & Answers
Frigidaire Side by Side Model:
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.-------
The control board needs to be inspected.----------
If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.--------
But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak
compressor.The refrigerant in the compressor is got low.The compressor
is weak.The compressor needs to be replaced.-------------- The working procedure of
this unit is as follows: --- The compressor starts then it cools the freezer
section. When the freezer reaches its cooling level the defrost cycle starts
functioning. In this cycle the fan in the freezer section starts running and the
cool air in the freezer section is passed to the fridge section and the fridge
section gets cold. The air from freezer to refrigerator passes from the
section, in that section the damper is located.------------ But as you mentioned
that freezer not cooling this indicates problem with compressor.When compressor
cools the freezer section then fridge section gets cold.If freezer section is
not getting properly cold then fridge section will not cool properly/.So the
problem relates to compressor.---------- In the compressor there is a
refrigerant called FREON.With the help of this Freon the compressor cools the
freezer section.Freon is a gaseous type cooling agent.The compressor will stop
cooling when coolant gets leaked from its chamber.--------- Again recharging the
Freon is possible, but the cost for that recharging is approx the cost of new
compressor.So its always advisable to get compressor replaced.Because new
compressor has warranty for few years.------------------ You can get required
parts from from online sites like: --- www.repairclinic.com or from
searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Insulation melted top by light
Good Afternoon Friend,
I understand the insulation has melted the insulation, near the top light, of your Frigidaire refrigerator, model# PHS68EJSB. With having the inside of your refrigerator melted, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of the melting was and how to resolve fixing your refrigerator. I hope this is helpful.
-Best Regards-
WP
How do I reset the temp on my frigidaire professional series fridge
Hi the best is to refer to your booklet or operational manual.However if it has been misplaced,open your door and you will see a button indicated TEMPERATURE CONTROL. when you depressed this button,corresponding temperature LED will illuminate say one for fair.two LED ,three LED and so if all LED are on that is too cold
Refrigerator temp is flashing
Good Morning James, thank you for your inquiry!
I understand your Frigidaire refrigerator is flashing. Let's try resetting your refrigerator by either unplugging it or flipping off the breaker for about ten minutes. If the flashing continues, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
My frigidaire is not cooling. my fans run and my
That could be an overload unit is fault due to fatigue or the relay that need to change from start winding to run winding is fault.if not the compressor is short cycling due to less refegrant gas in the systerm.Find a leak and regas after sealing it
