20 Most Recent Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Questions & Answers
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
12/17/2017 7:34:25 PM • Whirlpool... • Answered on Dec 17, 2017
Water under fridge sometimes ice
Defrost unit and work everything loose. Wipe off all water and let it sit over night. Plug in next morning and allow 24 hours for temps to be right.
9/9/2017 7:34:36 PM • Whirlpool... • Answered on Sep 09, 2017
How to shut off refrigerator and restart it at a later date
Unplug it
5/10/2014 2:46:29 PM • Whirlpool... • Answered on May 10, 2014
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
1/24/2014 9:50:07 PM • Whirlpool... • Answered on Jan 24, 2014
My Whirlpool side by side refrigerator is leaking
Hi,There was some issues with filter seals some years back and the filters had flat spots and caused the to leak. So if you are using a factory filter you can return it to the parts distributor and they will replace it. If its a after market filter I don't know what to say but us a factory filter to fix this issue.Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
11/11/2013 1:05:25 PM • Whirlpool... • Answered on Nov 11, 2013
GX5FHTXVY04 slow leak in bottom of freezer.
Your Temperature Control for the Refridgerator is bad, once you fix it your problem will go away
4/12/2013 12:29:49 PM • Whirlpool... • Answered on Apr 12, 2013
Water leaking onto the floor of the freezer covering the bottom with ice. Every few days we have to crack the ice and get rid of it .
the drain tube hole behind the inner rear panel in the freezer has plugged up and when it defrosts the water cant drain down to the condensate pan at the lower rear of the unit to evaporate
4/8/2013 11:26:52 AM • Whirlpool... • Answered on Apr 08, 2013
New french door 27 cu
The control board has a problem, we had the same problem and had the ice maker and control board replaced but we are starting to get ice building up under the ice bin. I'm very disappointed with this Whirlpool poduct.
2/21/2013 6:08:52 PM • Whirlpool... • Answered on Feb 21, 2013
0answers
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
85 questions posted
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
whirlpool refrigerator french door
  • Refrigerators
