First check
this things, is the compressor and fan on the compressor running. Mostly
it will run, because in most of the cases it runs. ---------- Now I will
explain the error code:---
There are
two types of error code which comes up on your refrigerator.
-------One
is 6 and 7 separate error code and other is combined 67 combined error code.
----As
per most of the cases on this LG model refrigerator you are getting error
code 67,
The error
code only 6 is run capacitor for compressor and error code 7 is problem with
compressor
But if
compressor and its components are running quite smoothly. Then its error code
67, which in most of cases been noticed. so as per error code, the fan motor is
issue.The evaporator fan motor issue.The evaporator fan
located in the freezer section.This motor for fan is getting inside over
heat and looses its communication with main board.
As
per error code, the fan motor needs to be replaced.
This will help.Thanks.Helpmech,.
40 questions posted
418 Questions
375 Questions
204 Questions
158 Questions
133 Questions
