20 Most Recent General Electric GSS25JET Side by Side Refrigerator Questions & Answers
Where is the temperature control panel of my GSS25JETA WW
It is likely there is no actual control panel, but rather a simple dial somewhere located towards the back of the inside the refrigerator compartment that has lettering that states, "warmer/cooler" with arrows that show which direction to turn to change the temperature setting.
7/11/2014 12:38:43 PM • General Electric... • Answered on Jul 11, 2014
I have a GE side by side refrigerator model gss25jetcbb that won't stop dispensing ice what is the solution to this problem
The problem is the ice dispenser itsels, there is an arm which lets the harvester know when it's full, probably stuck or broken.
11/22/2013 8:33:47 AM • General Electric... • Answered on Nov 22, 2013
Wondering if my digital Multimeter can c
It sure can! Take a look at this video.
11/9/2012 11:29:43 PM • General Electric... • Answered on Nov 09, 2012
0answers
My freezer has frost on back and my fridge is
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
8/18/2011 2:07:46 AM • General Electric... • Answered on Aug 18, 2011
3answers
PSS26PSTA side by side. Refrigerator appears ok.
you can test the sensors via voltage/temperature with a meter,but they are not that expensive and there are only 2 in the freezer section in this model and they cost about $15.00 each at the tops,cheaper than wasting time testing them by temp/voltage
3/2/2011 4:14:51 AM • General Electric... • Answered on Mar 02, 2011
0answers
How do I locate and replace the filter for the
most filters are located in upper left side of the refrigerators. here is a link to the owners manual for more instructions. hope this helps.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60401-2.pdf
12/20/2010 3:15:53 PM • General Electric... • Answered on Dec 20, 2010
I have a side by
http://www.partselect.com/refrigerator+ge-filter-removal+repair.htm
11/2/2010 3:22:12 AM • General Electric... • Answered on Nov 02, 2010
GE S/S GSS25JETA BB freezing up on back wall of freezer
This is a little work , but it will save you a service call , parts up-pricing , and labor .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and when to cycle off .
12/15/2009 4:03:57 PM • General Electric... • Answered on Dec 15, 2009
Fridge is freezing up.
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
5/15/2009 10:31:56 PM • General Electric... • Answered on May 15, 2009
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps: Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle. Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker. Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located. Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail. Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment. Reinstalling the Tray: To reinstall the ice tray, follow these steps: Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails. As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails. Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back. Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this: Remove the ice tray. Close the freezer door. Press the dispenser for cubed or crushed ice; you should hear a snap. Open the door again and reinstall the ice tray. Remember to handle the ice tray carefully, especially if it's full of ice.
3/31/2024 9:43:28 PM • GE Refrigerators • Answered on Mar 31, 2024
2answers
GE GNE27JYMFS Energy Star 27.0 Cu. Ft. French-Door Refrigerator. How long does the Sabbath mode last on a GE GNE27JYMFS please.
Question edited for a lot more clarity. Question moved from GE Ranges to GE Fridges. Sabbath Mode stays on until you turn it off. Press and hold the Lock and Light button simultaneously for 3 seconds to enter and exit the Sabbath Mode.
Bottom Freezer Refrigerator - Setting Sabbath Mode
GE Appliances https://products.geappliances.com > appliance > gea-supp...
Explanation of the Sabbath Mode Feature
GE Appliances https://products.geappliances.com > appliance > gea-su... Refrigerators with a Sabbath Mode feature puts the refrigerator in a timed defrost mode. It also turns off the icemaker, dispenser, and control touch screens. ..
1/16/2024 12:53:20 PM • GE Refrigerators • Answered on Jan 16, 2024
How do you replace the temperature control board on a ZICS360NRCLH. I don't see any screws or anything that is holding it up. Your assistance would be greatly appreciated thank you. Chuck
The Technical Service Manual says it is help by 3 magic slotted fasteners! Plus some RTV 102 seal which is this
Momentive RTV102 Adhesive/Sealant rtv 102, 2.8 fl oz ...
RSHughes https://www.rshughes.com > rtv102_white_3tg Momentive white RTV102 adhesive/sealant with a 72 hr cure time. Provides a 20 min fixture time. Delivers great performance with a shear strength of 200 psi, ... US$7.84 · ‎In stock Service Manual Page 24 https://www.manualslib.com/manual/739574/Ge-Zic36on-Series.html?page=24#manual //
12/29/2023 2:51:58 AM • GE Refrigerators • Answered on Dec 29, 2023
How do I install a filter for my GE Opal 01GENKT ice maker.
Question edited for clarity and toss in some CAPS. https://www.google.com/search?q=ge+ice+maker+model+opal01gepkt+filter+replacement I watched a video last night of a lady who took the side cover off and used a pipe brush to clean the black mold residue out of the pipes. I was pretty gross back there and she said it was only a year old. Check the side where the water connection is. https://www.youtube.com/results?search_query=clean+GE+ice+maker ..
12/27/2023 11:14:42 PM • GE Refrigerators • Answered on Dec 27, 2023
General Electric GSS25JET Side by Side Refrigerator Logo
26 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
ge s s gss25jeta bb freezing up back
  • Refrigerators
