20 Most Recent Crosley CW6000 Front Load Washer Questions & Answers
LE error code. The machine thinks the door is open. If it's not, then the switch or control board is faulty.
Crosley CW6000... | Answered on Jan 02, 2015
have u tried unplugging it a few minutes then restarting it? some units also have a shut down fuse and it may have shorted? U are getting power? other wise a bad terminal block
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Crosley CW6000... | Answered on Jul 11, 2014
I have had that happen a couple of times and by hitting the pause or cancel button a couple of times it then opened.
Crosley CW6000... | Answered on Mar 06, 2014
check your belt remove back cover
Crosley CW6000... | Answered on Dec 10, 2013
On our Kenmore front loader the guy came out and pulled the front lower cover off and opened the large round plug cap and there was the kids paint ball ammo stuck in the pre-pump end. Then he re-set the computer board with his tester. When this happened the second time, I repeated what he did, except I unplugged the unit. It cleared the memory and works fine...
Crosley CW6000... | Answered on Jun 05, 2013
Iwould feel around the top of splash guard and see if there is a obstruction.If not then cheak if there is a nail or screw stuck in the inner tub that maybe stoping it from spinning.If not you may need a thrust bearing kit.cheak the pully and see if you can turn the tub manualy if see thrust bearing if not tub bearing kit needed call for a repair man GOOD LUCK :)
Crosley CW6000... | Answered on Jan 28, 2013
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Crosley CW6000... | Answered on Jan 24, 2013
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
my washer agitator will not move or make its usual half turns it makes loud noise i went out and bought a new bas for it tryed it no luck went to take spline off offdrum to fix gaskets or whatever just to check wont come off
Crosley CW6000... | Answered on Dec 11, 2012
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Crosley CW6000... | Answered on Dec 07, 2012
You will need to replace the lid switch. Here is the part to order.
Below is a video to show you how to replace it. The model may be different but the repair process is the same.
Crosley CW6000... | Answered on Nov 27, 2012
Hi - Are you certain the error code is L7? This manufacturer does not have any L7 error codes for any washer or other units. I understand that it will not spin either; does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Crosley CW6000... | Answered on Oct 23, 2012
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace.
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Crosley CW6000... | Answered on Oct 01, 2012
Crosley CW6000 Front Load Washer Logo
63 questions posted
Top Crosley Washing Machines Experts
peter gittos
peter gittos
jdthefixer
Derek Bannister
Derek Bannister
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Washing Machines
Most Popular Question
crosley washing machine codes
  • Washing Machines
