20 Most Recent
Crosley CW5000 Front Load Washer Questions & Answers
How to unlock control panel
Hum u can check to see if the lock switch is bad by bypassing it with a jumper lead ( a SMALL pc of wire in the shape of a U ) to the ends of the prongs inside the machine not the switch? if it works then , u know its a bad switch OTHER WISE U MAY have a bad control board or bad connection to the switch and board were the wires have seized or cinged
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Won't drain water & hole
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Drain hoses should be changed by a competent person, either you or someone else AFTER REMOVING THE POWER! Both the one inside from the washer to the filter and the one connected away from the pump and into the plumbing u-bend should be accessible from where you remove the filter and see the pump and from the rear having taken the back off
John C
