20 Most Recent
Crosley CWDH11W Front Load Washer / Dryer Questions & Answers
I have the Crosley cfw8000gr front load washer and
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
IM looking for a manual for a model cah4205awj
Hello jojothunder3,
I understand that you need a manual for your Crosley washer dryer the only place that I could locate the manual is Sears Parts Direct and you have to call to see if it is available at this number (800) 252-1698 the part number is #2206690 and is called a use and care manual.
Thank you for choosing FixYa.com
justinbur167
Crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Crosley CFW8000GR OE Problem
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
Why won't my washing machine spin?
There could be several reasons why your Crosley washing machine is not spinning properly during a regular cycle. Here are some possible causes:
- Unbalanced load: If the load of laundry is not evenly distributed in the drum, it can cause the machine to become unbalanced and not spin properly. Try rearranging the clothes and see if that helps.
- Drive belt: The drive belt may be worn, loose or broken, preventing the machine from spinning. Check the belt and replace if necessary.
- Motor coupling: The motor coupling connects the motor to the transmission. If it is broken or worn out, the machine may not spin. Inspect the coupling and replace it if necessary.
- Lid switch: The lid switch prevents the machine from spinning if the lid is open. If the switch is faulty, the machine may not spin. Test the switch for continuity and replace it if necessary.
- Motor: If the motor is faulty or burned out, the machine may not spin. Test the motor for continuity and replace it if necessary.
If you are unsure of how to check or replace any of these parts, it is recommended to consult a qualified technician.
Why won't my Crosley top load washer pass wash cycle?
There are several reasons why your Crosley top load washer might not be passing the wash cycle. Some common causes include:
- Power issues: Check to see if the washer is properly plugged in and the outlet has power.
- Water supply problems: Make sure the water supply valves are turned on and the hoses are not kinked or clogged.
- Load balance: The washer may not be able to advance to the next cycle if the load is unbalanced. Try redistributing the clothes evenly in the drum.
- Control panel issues: The control panel or the control board may be faulty and need to be replaced.
- Lid switch: If the lid switch is not functioning properly, the washer may not be able to advance to the next cycle.
- Clogged pump or drain: If the pump or drain is clogged, the water may not be able to be pumped out of the washer, causing it to stop mid-cycle.
If you are unable to resolve the issue on your own, it may be best to consult a professional for further assistance.
What do codes F6 E1 mean?
i think theres a problem with the motor control board because of no proper operation or turning it off suddenly. Just try to shut down your breaker and if theres a reset button on your machine press it might help.
