20 Most Recent
Uniden Solara DSC VHF Marine Radio Questions & Answers
My sound went out can I buy a new speaker
The first to do is to understand if is the problem of the speaker or is a software problem.
Firs you check if is problem with your speaker:
you can place headset and see if have sound or not. Or put your speaker in an other computer to check if they work.
If the speaker are ok you need to check the pc.
How do i wire radio to a deep cycle or a starting battery
I realize this question has been around for a looooong while, but if anyone else needs the information, the RED wire goes to the positive terminal of the battery while the BLACK goes to negative. I have included a link which will show you the features of this radio as well as the Owners Manual.
Regards, Steve
Why my uniden has no squech or sound but transmits
Hi Although this question is an old one, I\'ll do my best to answer it in case someone else has the same issue. This is condition is nearly always caused by a cabling problem usually where the antenna connects to the radio. Carefully inspect the connector for obvious damage, clean the connection with silicone spray (safe for plastics) and reconnect the antenna several times. While you\'re at it, check and clean the power connections as well, both at the radio and the battery/power panel connections as the problem could be as simple as a poor ground. This problem could also be the fault of a broken wire/poor solder joint in the PL-259 plug itself. If you\'re handy with a soldering iron, take the connector apart and make sure the centre pin connection is securely soldered as well as the ground braid soldered securely to the case of the PL-259. I\'ve included the link to Uniden\'s marine electronics owner\'s manuals and the support page. I\'ve had pretty good luck in the past when I\'ve had to contact Uniden. Hope this helps. -Steve
scat=marineelectronics_mnl">Select Product Category Marine Radios
