20 Most Recent
Seiko Pulsar Dress PJ6010 Watch for Men Questions & Answers
My Seiko Pulsar Dress PJ6010 was running fine
D you mean battery drain, not gain? Possible other causes are: Maybe you got an old battery put in, this does happen sometimes. Or, maybe the lubricants have dried out causing the gears to get sticky/gummy and causing excessive battery drain. I use an instrument than spin the movement and loosen up sticky gears after using a spray cleaner.
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
Reset time on a seiko solar watch
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
