20 Most Recent As Seen On TV Magic Bullet Food Processor Questions & Answers
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
As Seen On TV... | Answered on Feb 11, 2019
I PUT MY FRUIT IN IT AND IT WIZZED FOR LIKE 2 SEC BEFORE IT CUT OUT AND NOW I CANT GET IT TO WORK PLS HELP
As Seen On TV... | Answered on Feb 24, 2016
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
As Seen On TV... | Answered on Aug 09, 2015
Sounds like the white plastic sliders that turn the motor on and off may be stuck. The sliders engage the 3 tabs on the mixer cup which the push down and turn the motor on. Probably have some leakage from the mixing cup gumming the white sliders up. Unplug the mixer from power and use a cloth or sponge fairly wet with some hot water to try and loosen up the stuff under the sliders. Then spritz the sliders with some WD-40 which will displace the water. Dry it off good with a paper towel, let it dry/drain well upside down on a paper towel before you plug it back in. Good luck.
As Seen On TV... | Answered on Dec 13, 2014
Take a look on amazon here Amazon com magic bullet blender parts. I hope it was helpful. enjoy
As Seen On TV... | Answered on Nov 22, 2014
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
As Seen On TV... | Answered on Nov 19, 2014
Push down and twist.
https://www.nutribullet.com/customer-service.html
As Seen On TV... | Answered on Aug 15, 2014
Have you already been here? https://www.nutribullet.com/register/
For a Step-by-Step instructional PDF on how to disassemble, clean and reassemble your Magic Bullet send an email request to: Tinker@TinkersWorkshop.com.
As Seen On TV... | Answered on Mar 14, 2014
Food Processors Logo
164 questions posted
Top As Seen On TV Food Processors Experts
gggg
ray gallant
Are you an As Seen On TV Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • As Seen On TV Food Processors
Most Popular Question
magic bullet blender repair
  • Food Processors
