20 Most Recent
Lenovo ThinkPad Edge E430 Laptop Computer Questions & Answers
Two beep sound with no display
- First of check is your RAM inserted in ports correctly?- Clean the Processor fan, Heat Sink and other peripherals.- Use High Speed fans.- Start PC in safe mode.- Download program PCFresher.- Run its all tools.Your problem will be solved.
When pressing number on laptop its showing characters
From your description I must assume that if all other keyboard functions and keys work properly then the keyboard is faulty. For the number keys to print the upper case characters shown on those keys requires a shift key to be depressed or stuck. If all other keys work properly, replace the keyboard. Otherwise look for a stuck shift key. I have found keyboards for sale on Ebay.
Restart hangs
- Start PC in safe mode, normally Pressing F8 key when windows starts up.( Google it)- In Safe Mode create a new user, with administrator privileges and protect it with password.- Remove unwanted software's & programs.- Empty the Recycle Bin.- Download reliable program RegInOut to fix OS registry properly. - Restart your PC normally and log on to the new account created.Stay Happy :-)
Lenovo E430 is very slow
Run Disk Cleanup:-Efficiency of laptop decreases when it contains too many junk files. To clean junk content from your system follow the steps below:- Click Start- Type Disk Cleanup- Press Enter- Select the drive which you wish to clean- Click OKFix Registry Errors:-Mostly laptop runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Two beep sound with blank display
removed the battery and charger and try holding the power button for at least 10 seconds then replaced battery and charger then press the power button..
Slow microsoft
your laptop may be slow due to following reason - Too many programs running at startup or in the background- Data Corruption, hard disk fragmentation- Missing Windows updates or outdated drivers- Not enough hard drive space, too many unused programs- Left over programs, old cached and temporary filesSo Follow these steps to fix computer problem::- Delete all the temp files- Remove unused programs- install latest drivers from the manufacturer site- Install and run antispyware software- Free up wasted space with Disk Cleanup tool- Defragment your hard disk driveIf you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
How to connect an onn wireless mouse to a lenovo chromebook? i tried doing this 3 times and still wont connect.
Firstly, try turning over your Bluetooth mouse and find the power switch. Make sure it's turned to ON.
You should see the optical light turn on (usually red). Place the mouse back flat on your mouse pad.
On your Chromebook, select the lower right corner of the taskbar. In the window that pops up, select the Bluetooth icon.
If the Bluetooth status is currently off, enable the toggle switch to enable Bluetooth. Once enabled, you'll see a scanning status as your Chromebook looks for active,
nearby Bluetooth devices. When your wireless mouse appears, you can select it to pair and connect to it.
Once your Chromebook has made its connection with your Bluetooth wireless mouse, you'll notice the mouse pointer moving when you move your mouse
Lenovo ThinkPad L510 boot menu disabled
Repeatedly tap the F1 key when the Lenovo, ThinkPad, ThinkStation, or ThinkCentre logo appears, The computer may beep once to indicate that it will boot to BIOS.
How to Enable Boot device List F12 Option
The following example shows a system that has an option to enable or disable the Boot device List F12 Option.
Go into the BIOS to enable Boot device List F12 Option (option is usually under the Startup tab).
