20 Most Recent
Canon Pixma MG3150 All-In-One Color Printer Questions & Answers
I'm getting error e02 it does have paper
Canon Printer E02 Error is a mechanical fault, that cases up to the printing process of a printer. This technical error can happen due to overheating taking up the place in the print head. The overheating in the printer can stop the printing to take place. This can become a frustrating factor for a user.
Solution to fix Canon Printer Error E02:-
1. Switch off the printer.
2. Soon, open up the print head.
3. Switch on the printer to make the process further.
4. Following this, you will see the ink cartridge will move from the right to the left.
5. When the ink cartridge moves, closed the printer cover.
6. To Continue Reading check this Blog-
Canon MG 3150 I have a bogus paper jam error(E03) which will not clear.
While not quire familiar with this printer I have some ideas.
first most paper detection involve either mechanical switches or sensors. The sensors use the white paper either to reflect or block the sensor beam. Then as paper moves through logic resets. ( from your message I think you know these but just put as refresher).
you have checked for physical paper and found none, so I would get a can of air and spray sensor slots as paper dust can build up over time and the dust looks like paper to the sensor. If you have air compressor open all cover and remove ink or toner and spray away.
this is more prevalent in the higher speed printers, but can build up over time.
Not sure if the printer says where the jam is located which would be helpful.
My black ink has run out but even after I set it to print from color only, it prints me a blank test page?
Are you sure the color ink hasn't dried out?Pull the cartridge and carefully wipe the print head across a facial tissue or paper towel. Don't touch the metal contact points on the cartridge as sometimes the smallest static charge can destroy the cartridge.Depending on the printer, setting it to color it may use only the color cartridge, but more likely it will use both the color and black to make up the print. Setting to black and white, not grayscale will force it to use only the black cartridge.Here is an explanation, much like I suspected, and a cure. (Fixya doesn't allow me to add a link at this point, so you'll have to drop this into your address bar.)http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Paper completely jammed
Lift feed panel, then the cover. carefully pull in thedirection of normal feed onto the scan plate. Do not try to pull out from the entrance.
How do i install a canon printer
You should have a disc that has all the drivers on to work the printer on your computer, if not go onto the Internet and type canon then make sure you select a Canon site not just one that offers canon info and along near the top should be a list of things to connect to chose driver updates, you can then choose your printer from a list then just download the drivers from there open and run them all should work then
