20 Most Recent Casio fx-115ES Plus Scientific Calculator Questions & Answers
Where is the EE button on my Casio fx-115es plus calculator
No EE button (on Texas Instruments). Use the x*10^x
5/22/2018 1:01:28 AM • Casio fx-115ES... • Answered on May 22, 2018
Do not know how to calculate [H3O] from pH
pH=-log[H3O+] [H3O+]=10^(-pH)
12/7/2015 5:15:44 AM • Casio fx-115ES... • Answered on Dec 07, 2015
When I cube roots it gives me a decimal instead of a root answer how do I convert or fix this?
Did you ever think of consulting the manual that came with the unit?and if you do not have it, you can always download it from the website.
11/10/2015 4:57:03 PM • Casio fx-115ES... • Answered on Nov 10, 2015
Is there a way to lock the SD key so my answers are always in decimal values and not fractions?
Configure the calculator to display result by default in decimal. Press SHIFT MODE (SetuP) and choose the LineIO input-output .
8/5/2015 7:57:34 PM • Casio fx-115ES... • Answered on Aug 05, 2015
Convert from degrees minutes seconds to decimal degrees
Use the DMS (deg, ' '') key.
7/29/2015 12:29:41 AM • Casio fx-115ES... • Answered on Jul 29, 2015
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result. If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
2/3/2015 3:21:42 AM • Casio fx-115ES... • Answered on Feb 03, 2015
On Casio FX-115ES Plus Calculator, what buttons do I push to do compound interestsemiannually for 15 years?
There is no such button. You must figure out the formula and enter it, giving the appropriate value for the annual interest and the number of years (15).
9/28/2014 10:37:52 AM • Casio fx-115ES... • Answered on Sep 28, 2014
Why my display is not working properly?
Meaning what, exactly?
9/19/2014 12:13:05 AM • Casio fx-115ES... • Answered on Sep 19, 2014
How do i get the ee to work on my casio fx-115es plus?
What you call the EE ((entering power of 10 exponents) is done with the help of the key at the bottom right, and marked [x10^X]. To enter 6.02x10^23, you do as follows 6.02 [x10^X]23. When you use that short-cut key, no 10 should appear on the command line. See screen capture. 41e84ea3-2658-49be-8ce0-51b7ea24192c.png
9/8/2014 8:16:05 PM • Casio fx-115ES... • Answered on Sep 08, 2014
Fix scientific calculator
Increase the contrast. Press [SHIFT][MODE] to enter the SETUP. Use the down arrow to locate the contrast option. Use the Right arrow to increase the contrast.
8/22/2014 10:33:44 PM • Casio fx-115ES... • Answered on Aug 22, 2014
How do I do feet and inches calculations on the Casio FX-115ES Plus? For example, how can I do calculations like 10'-3" + 5'-4" + 11'-11" without having to convert the inches to feet?
Calculators work to base '10' not base '12', so you'll have to convert. the S.I. unit of measurement is used for calculators which is metres and they are base '10'. The metre was calculated by a french bloke who got the calculation wrong, but they still use it. Feet and inches are better.
7/23/2014 12:04:55 AM • Casio fx-115ES... • Answered on Jul 23, 2014
You can combine all the feet together 10+5+11=26 feet Combine all the inches together -3-4-11=-18 inches=-2 ft + 6 inches 26 ft -2ft +6 inches =24 ft +6 in=24.5 ft You can also multiply each inch -value by 1/12 10-3/12+5-4/12+11-11/12=10+5+11 -(3+4+11)/12=26-18/12, continue
7/22/2014 4:28:51 PM • Casio fx-115ES... • Answered on Jul 22, 2014
How to get l1 l2 l3 charts
L1, L2, L3?If you are doing statistics, Set MODE to 3. Stat.Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.For any regression model you have 3 lists x, y, and Freq(uency).L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.I hope it helps
10/27/2013 11:12:28 PM • Casio fx-115ES... • Answered on Oct 27, 2013
How do i get l1 l2 l3 charts up
L1, L2, L3?If you are doing statistics, Set MODE to 3. Stat.Choose 1-Var or any regression model. If you press 1-var you will have two lists x and frequency.For any regression model you have 3 lists x, y, and Freq(uency).L1, L2, L3, are list names in the TI 83/84 Plus and the Casio graphing calculators.However I have no idea what getting the charts up mean.I hope it helps
10/27/2013 11:12:09 PM • Casio fx-115ES... • Answered on Oct 27, 2013
Inverse log function
For the common antilog, use the 10^x function available as the shifted function of the log key. For example, to calculate the common antilog of 2, press SHIFT log 2 =If you want the natural (base-e) antilog, use e^x available as the shifted function of the ln key.
8/5/2013 11:08:40 PM • Casio fx-115ES... • Answered on Aug 05, 2013
How to use standard deviation on a casio fx-115es plus
Follow the instructions under "Statistical Calculations" beginning on page E-44 of the manual. Examples 053 through 059 in the Appendix show an example (especially 057).You may download the manual and the appendix from http://support.casio.com/manualfile.php?rgn=1&cid=004001004
5/7/2013 4:40:05 AM • Casio fx-115ES... • Answered on May 07, 2013
How to find the Standard deviation on my calculator?
5/7/2013 4:40:01 AM • Casio fx-115ES... • Answered on May 07, 2013
Standard deviation on a casio fx-115 ES PLUS
Follow the instructions beginning on page E-30 of this manual.
4/6/2013 3:03:17 PM • Casio fx-115ES... • Answered on Apr 06, 2013
Casio fx-115ES Plus Scientific Calculator Logo
32 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
inverse log function
  • Office Equipment & Supplies
