20 Most Recent
Sega Sonic Riders: Zero Gravity for Nintendo Wii Questions & Answers
Multi player
Well: first. press the home button then go down and click wii remote setting s then click disconnect wii remote then both of you press the 1 and 2 buttons until it recognizes your wii remotes.
+ wont work at start menu
Well i can tell u its not the game because i have it and it works fine . Have u ever tried with a different remote or re syncing it
I can't get started.
We had the same problem. Turned out that if you have an original gamecube controller plugged in at the same time you are attempting to use the Wii remote it will only let you use the gamecube controller. Unplug the gamecube controller and you can now use the Wii remote. Or, you can choose to use the Gamecube controller. Both will work.
Playing WIIs Sonic Zero Gravity
The trick is, you have to sync up the 2nd controller to the Wii before starting the game.
Turn on the Wii, there's a small cover below the DVD drive that you flip down, (This is also the spot where your SD Memory card can go) There's the red button.
Open the battery area of the 2nd Wii remote. You'll see a small red button.
Press both the red button the Wii Console & the Wii remote. Then it should turn on & Sync.
Once that's done, start the game. It will then recognize the 2 controllers.
-T
Multple players
You'll see 2 wii remote's on the main screen (1) & (2) Once that's sync'd your ready to play!
-T
I have a sega genesis hd and my screen is black my hd tv screen how do i get a picture
Depending on how you are looking it up, you would need to be on channel 3 or 4 on cable or antanna if it's hooked up on the RF. If you are using the yellow and white and you don't have a yellow port put it in the green port. But the best why to get it hooked up is by HDretrovision cables, it will give you the best picture. But the cables are not cheap.
Ive got a sega dinosaur
How did you get it? also you could call up a gameworks the people who work on them have to deal with that all the time.
