20 Most Recent
Nikon Speedy-K Autorefractor Questions & Answers
AUTOREFRACTOR
White screen is a video card problem.Maybe your device is working with a full memory, and have to be cleaned.I need more informations in
[email protected]
The negative mount is jammed
Removed the outer cover - remove the screws on back and bottom then slide it off. Re-latch the tray cover.
I hope this helps. Let me know if you need further assistance.
After working correctly for several
So, you tried to reinstall the drivers ?
http://h10025.www1.hp.com/ewfrf/wc/g...reitem=sj655czCan you see the scanner in Device Manager? Click on Start, right click on My Computer, then choose Properties... . Click on the Hardware tab, then click on Device Manager. Look for any ?'s or !'s that you see. Or, check for the scanner under Imaging Devices. Do you at least see the scanner device? If you do, then you've at least narrowed it down to perhaps an application issue.
What
error messages do you get when you try to scan?
Thanks
LS400 works ok after re-boot
That means that the USB turns off when you go to hibernate. This means that the USB port is configured to turn off when you go into hibernate to save power but does not come on. This can be chagned in the control panel then power options or power management. So that I can give you more specific instructions kindly provide me with the type of windows that you are using as well as the brand and model of your computer.
Nikon coolscan 3 LS30
This can be a software issue , so better check if there's any software update go ahead update the software of this and that should fix it..
Hope that helps........
WE HAVE A NIKON CAMERA
Hi
Some printing is get struck while printing please try with cancel that printing otherwise restart both the system and printer it will solve your problem
Boopathy.T
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
