20 Most Recent
Autodesk AutoCAD 2006 Questions & Answers
Autodesk Maya 2010 Key serial number where
Hello
Unfortunately we are not permitted to provide serial numbers in
accordance with our terms and conditions and the DMCA copyright laws.
If you bought the product legally you should contact the manufacturer.
The contact details should be on the side or back of the box or CD
cover.
I hope you understand. Feel free to contact me if you have any questions.
Kind Regards
Andrea
Description:
AutoCAD 2006 is
It could mean your OS is incompatible with the software and you need an updated version that's compatible with your platform and OS. Are you using Windows 10? It could also be that you have NET 4.6 installed. Sounds more like that could be the problem to me. Check to see if you have it installed. If that's the case then just uninstall NET 4.6, restart the computer, then install Autocad. Then you can reinstall NET 4.6.This should work for Win 10/ 8/ 7Go to Control Panel> Programs and Features> look for NET 4.6 framwork and uninstall it.
Autocad file cannot be opened, how can I open it?
Use the autosave files to recover your work
1. Go to Tools --> Options
2. Inside Options go to the "Files" Tab (far left)
3. Inside the files tab go to: "Automatic Save File Location" and see where the autosave files are stored. (mine where stored at C:\Documents and Settings\USERNAME\Local Settings\Temp)
4. Then access that folder and try to find a file with the same file name but different extension. (The autosave files should have a either a .BAK or a .SV$ extension) (if you can't see the folder, you need to go to Tools --> folder Options --> View --> and Make sure "show hidden files and folders" is SELECTED) .
5. Check the "date modified" of those files, if the date and time makes sense according to when you had the last file crshes, there is a good chance that those files contain the information you need, so there is no need to redraw everything.
6. Change the file extension of the file you think it might be the good one from .bak or .sv$ to .dwg (to be able to change the file extension you need to be able to see it. To do that, on any folder go to Tools --> Folder Options --> View --> and make sure that "Hide extensions for known file types" is UNCHECKED)
7. Use third party software in case the guide about wasnt effective
DWG Repair Toolbox
http://www.autocad.repairtoolbox.com/
