20 Most Recent
LEGO interactive LEGO Creator Harry Potter for Windows Questions & Answers
Game crashes and won't start
I have the same problem, and I have just recently solved it. What you need is a graphics card, and that cost money. If you don't want to spend the money on the graphics card then you should just send the game back because there is no point too it, it will never work properly without the graphics card. I hope this helps.
For year 3 level 6
It's not a glitch. You have to cast a spell on the light, melting the ice aroudn the light, filling the fountain with water, and in return filling up the bucket of water.
Game locks up
Hi, jercal10
Try to update your video card driver then re-install your game.
Hope this helps
Thx
Banaple
Lego Harry Potter crashes on my Windows Vista
I have the same exact problem as you. The only thing we can find wrong with the game is that there is something wrong with the application's code, or nothings wrong with the game and you need a graphics card, which cost money. There are only a few others who have this exact same problem that I've searched and there has been no solution. My best guess is try the graphics card and if that doesn't work then you should just send the game back becuase there is something wrong with it. Also if you look into the game requirements you will find that your computer might not reach the standards in which the game needs too play. I'm not sure If this will help or not, but it is worth a shot.
When installing Harry Potter LEGO Creator, I'm
Pop the CD in and then Exit from the Autorun screen.
Go to explore the CD and find the Installer icon. Right click and go to Properties. In Properties click the Run in Windows 98 box. Right click again and then hit Run as Administrator. This solved it for me.
A problem with installing lego creator harry potter.
Try cleaning the disc first. There may be dirt or fingerprints interfering with reading it. The CRC error means the data is not being read correctly. If the error continues and this is a game you recently purchased, I would recommend returning it to the store and exchanging it as it's probably a defective disc. If you are trying to install a copy you downloaded you should try downloading again as there is some error in the data.
Sa ne marche pas
si ton jeux et un fichier image faut avoir le bon programme pour le loader Utilise Daemon Tools
