20 Most Recent Robot Coupe CL50 Food Processor Questions & Answers
0answers
Robot chef RC3 lid the little bit on the lid that
To valewis46 - is the lid still available as mine has been stick together that many times that it has now bitten the dust. I realise that your offer was made over a year ago but I thought I would ask - just in case. Thanks.
1/5/2013 1:10:55 PM • Robot Coupe CL50... • Answered on Jan 05, 2013
I have a robot chef food processor it says type
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
9/24/2011 9:33:26 AM • Robot Coupe CL50... • Answered on Sep 24, 2011
Can,I get the Spare cutter
Are you looking for a new 'disc' for your product? You may be in luck. Have a look at this site, click on the drop down menu , Discs for the CL50 Gourmet:
http://www.robotcoupeusa.com/products/product-info.php?id=79
3/1/2011 5:34:16 PM • Robot Coupe CL50... • Answered on Mar 01, 2011
I have a rc3 food
Only directly from them  http://www.robotcoupe.net/food-processor-parts-by-models.html
8/18/2010 5:18:26 AM • Robot Coupe CL50... • Answered on Aug 18, 2010
Robot coupe maintanance
That plastic piece is a sling disk or sling blade and made to sling product to the discharge chute. Believe it or not, the motor shafts wear out and could be the cause of premature failure. When you install the new sling blade, check to see how much slop/ play there is by moving this back and forth on the shaft, a small amount is ok (1/16th to 3/32nds). The other thing to look at is forcing or overfeeding the unit. You can contact them at Robot-coupeusa.com
7/25/2009 4:53:59 AM • Robot Coupe CL50... • Answered on Jul 25, 2009
Robot Coupe blade sraping top lid and metal in getting in cheese
3BX9k4 PLEASE DESCRIBE IN BRIEF WHAT THE PROBLEM IS?
3/24/2007 2:50:26 PM • Robot Coupe CL50... • Answered on Mar 24, 2007
I purchased a Robot Coupe R101 and wanted to add the Pulse button. Do I just get a R101 Plus switch and front panel? How hard is the replacement? Thanks
To add the pulse button to your Robot Coupe R101, you will need to purchase the R101 Plus switch and front panel. The replacement is relatively simple and can be done by following these steps:
  1. Turn off and unplug the Robot Coupe R101.
  2. Remove the screws that hold the top cover in place and lift off the cover.
  3. Locate the control panel on the front of the machine and remove the screws that hold it in place.
  4. Carefully remove the control panel and disconnect the wires from the old switch.
  5. Install the new R101 Plus switch onto the control panel and connect the wires.
  6. Replace the control panel onto the front of the machine and secure it in place with the screws.
  7. Replace the top cover and secure it in place with the screws.
Once the new switch and front panel are installed, you will have the pulse button on your Robot Coupe R101.
2/24/2023 6:24:36 PM • Robot Coupe Food... • Answered on Feb 24, 2023
I have a Robot Coupe Blixer 4 V series A. The blade is stuck causing the "bowl" to not unlock and come off.
Pour penetrating oil down the upper shaft if possible. Remove the allen scews from the base with 5/32 T handle wrench. Remove the round snap ring on the motor shaft. Use vise grips or channel lock to secure the shaft. Twist the blade off and inspect it. It most likely will need to be replaced as the key that slides on the shaft will have deteriorated.
9/12/2022 5:25:53 PM • Robot Coupe Food... • Answered on Sep 12, 2022
Robot coupe 3b wiring diagram
Wiring diagrams are in the back of the manuals after the parts lists.https://www.partstown.com/robot-coupe/blixer-3b/parts#id=mdptabmanuals..
5/20/2022 10:53:06 PM • Robot Coupe Food... • Answered on May 20, 2022
2answers
Model R602 V.V.F. How can I remove the upper case from the base of the machine?
you look for hidden screw perhaps under a label
5/9/2021 6:53:35 PM • Robot Coupe Food... • Answered on May 09, 2021
Where can I get spare parts for a robot chef food processor RC3
Hi im after a replacement lid for my robot chef rc3 if anyone has a spair one please email me at [email protected]
5/8/2018 9:13:23 PM • Robot Coupe Food... • Answered on May 08, 2018
Robot Coupe CL50 Food Processor Logo
20 questions posted
Top Robot Coupe Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Robot Coupe Food Processors
Most Popular Question
robot chef food processor says type
  • Food Processors
