20 Most Recent
Sega The Club - Xbox360 for XBox 360 Questions & Answers
What's your problem?Im trying to hook up my
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
What power cord for xbox 360
There are 4 different types of power chords for the 360. First you need to find out what console you have then you can find out what power supply model you need.
Cheat superman
Woah woah wagon slow down you can go to youtube that's how I got all of them and really isn't a superman cheat unless it's a mod
Cheat codes for black ops
I hope this helps
Cheat mode:
At the main menu, use the Right Analog-stick to look down at your hands and see you are locked up. Repeatedly press LT + RT to escape from the chair (unlocks the "Just Ask Me Nicely" secret achievement). After breaking free, move around to the area behind your chair to find an old computer terminal you can use to access the Central Intelligence Agency Data System. Type one of the following codes to access early unlockables and hidden features in the game.
Note: You can also plug a USB keyboard into your Xbox 360 to enter the codes and play the Zork text-based adventure game.
Mission select, "Five" Zombies mode map, Dead Ops Arcade game, and Zork gameEnter "3ARC UNLOCK" as a code to unlock the "Five" Zombies mode map, Dead Ops Arcade game, Zork: The Great Underground Empire text-based adventure game, and all missions.
All IntelEnter "3ARC INTEL" as a code to unlock all Intel. Note: Enabling this code will prevent the "Closer Analysis" achievement from being earned.
Alicia gameEnter "ALICIA" as a code to unlock the Alicia virtual therapist game.
Dead Ops Arcade gameEnter "DOA" as a code to unlock the Dead Ops Arcade game, which is a zombie killing mini-game similar to Smash TV. Use the Left Analog-stick to move and the Right Analog-stick to shoot. Note: Play the Dead Ops Arcade game to get the "Insert Coin" achievement.
Zork gameEnter "ZORK" or "HELLO SAILOR" as a code to unlock the Zork: The Great Underground Empire text-based adventure game. Note: Play the Zork game to get the "Eaten By A Grue" achievement.
Display all commandsEnter "HELP" as a code to display a list of system commands in the terminal and Pentagon user e-mail access.
Open corresponding fileEnter "CAT [filename]" or "PRINT [filename]" as a code to open the corresponding file.
List audio files and picturesEnter "DIR" as a code to display a list of audio files and pictures for use with "CAT" command.
List of login namesEnter "WHO" as a code to display a list of login names for use with the "RLOGIN" command (requires passwords).
LoginEnter "LOGIN" as a code to login with a corresponding username and password.
Open mail folder for current userEnter "MAIL" as a code to open the mail folder for the current user.
Display contents of current directoryEnter "DIR" or "LS" as a code to display the contents of the current directory.
Encode a string using the CIA's cypherEnter "ENCODE" as a code to encode a string using the CIA's cypher.
Decode a string using the CIA's cypherEnter "DECODE" as a code to decode a string using the CIA's cypher.
Display "Fee Fie Foe Foo!"Enter "FOOBAR" as a code to display "Fee Fie Foe Foo!".
- Dreamland serverAccess the Central Intelligence Agency Data System. Enter "rlogin dreamland" as a command. You will be prompted to login with an account with MJ12 access. Use one of the following usernames and passwords to continue:
Login as Robert Oppen: Username: "roppen", Password: "trinity"
Login as T. Walker: Username: "twalker", Password: "thanksdad"
Login as Vannevar Bush: Username: "vbush", Password: "majestic1"
- Terminal accessAccess the Central Intelligence Agency Data System. Enter "login" as a command. You will be prompted to login with an account. Use one of the following usernames and passwords to continue. You can then access their documents with the "dir" command or e-mail with the "mail" command.
Person
Username
Password
Adrienne Smith
asmith
roxy
Alex Mason (default account)
amason
password
Bruce Harris
bharris
goskins
D. King
dking
mfk
Frank Woods
fwoods
philly
Grigori "Greg" Weaver
gweaver
gedeon
J. Turner
Jturner
condor75
Jason Hudson
jhudson
bryant1950
John McCone
jmccone
berkley22
Joseph Bowman
jbowman
uwd
John F. Kennedy
jfkennedy
lancer
Lyndon B. Johnson
lbjohnson
ladybird
Richard Nixon
rnixon
checkers
Richard Helms
rhelms
lerosey
Richard Kain
rkain
sunwu
Ryan Jackson
rjackson
saintbridget
T. Walker
twalker
radi0
Terrance Brooks
tbrooks
lauren
Vannevar Bush
vbush
manhattan
William Raborn
wraborn
bromlow
- Secret GamerpicsEscape the interrogation chair by repeatedly pressing LT + RT at the main menu to unlock the Frank Woods Gamerpic. Log into Jason Hudson's account on the terminal to unlock a Jason Hudson Gamerpic.
In the "Annihilation" DLC, get the "Time Travel Will Tell" achievement to unlock the Dempsey and Richtofen Gamerpics.
- Hidden Thunder Gun in "Numbers" missionAt the beginning of Mission 7: Numbers, after the Nova 6 Gas is released, go to the back of the room, and enter the office. Find the tape recorder, and hold [Action] to pick it up. If done correctly, the screen will shake. Continue through the level until you get to the part where you jump off the roof into the building and onto the mattress. Once Clarke is inside, he will move a fridge leading to the weapon stash. You must watch him move the fridge or you will not get the Thunder Gun. Once you get inside the stash, go to the left. You should see another tape recorder. Walk up to it, and hold [Action] to pick it up. If done correctly, the screen will shake and the Thunder Gun will appear from the wall. You can trade the weapon you are holding for it, and it will be equipped with twelve shots. After you get the Thunder Gun, the rest of the level should be very easy.
In Mission 7: Numbers, after interrogating Clarke, several enemy soldiers will appear at the end of the long hallway. If you shoot all six Nova 6 canisters (two in the back, four on the sides), you can retrieve a cassette tape in the office behind where you started. Note: It is recommended that you toss a flashbang to blind the enemies so you can shoot the canisters more easily. Once you pick up the tape, continue progressing through the mission until the part where Weaver and Clarke both jump off the roof and onto a mattress. After they jump down, Clarke will ask Weaver to help him move a fridge out of the way to his first weapon stash. Once they do, go inside, and look to the left. There should be a place to put the cassette. Note: When picking up and placing the cassette tape, the game will not prompt you to do anything -- you must use this information to know when to do these things. Once you insert the cassette tape, the screen will shake, and the Thunder Gun will appear out of the wall. It has twelve bullets, and it is reloaded at checkpoints.
- All Zombie mapsSuccessfully complete the indicated task to unlock the corresponding Zombies mode map:
Dead Ops Arcade: Play the Dead Ops Arcade game or successfully complete the game. The map description reads "Step back through time with this retro arcade zombie adventure and do battle with the forces of the Cosmic Silverback."
Der Riese: Requires a unique code that is included with the Call Of Duty: Black Ops Hardened and Prestige Edition.
Five: Successfully complete Campaign mode on any difficulty. The map description reads "The Pentagon is under attack! Washington is going to DEFCON 1 in this installment of "Zombies"."
Kino Der Toten: Available at the start. The map description reads "Battle the undead in this theatrical installment of "Zombies". New twists and clues could uncover the final plan. It's show time!"
Nacht Der Untoten: Requires a unique code that is included with the Call Of Duty: Black Ops Hardened and Prestige Edition.
Shi No Numa: Requires a unique code that is included with the Call Of Duty: Black Ops Hardened and Prestige Edition.
Verruckt: Requires a unique code that is included with the Call Of Duty: Black Ops Hardened and Prestige Edition.
- Finding the Pack-A-Punch on Five map in Zombies mode
Make a crawler, then go into the middle room, and adjust the DEFCON level to DEFCON 5. All teleporters will take you to the Presidential Suite. All switches are in that room; three are upstairs and one is downstairs.
Forgot my password for my xbox account
Windows live accounts like hotmail etc, all have the same account passwords. So the X-box is the same as those. If you have forgotten your password to x-box live go to the x-box live site and submit a forgot password entry.
Need to know why the red light keeps coming on
If you purchased it new from a trustworthy retailer just 3 months ago, and are already getting red-ringed, then send it into Microsoft ASAP. The warranty should still be good on it if it was indeed purchased new, and they will fix it or send you a new Xbox depending on the status of the problem. If it's purchased used or from a 3rd party-then you are out of luck and need to get a repair kit, take it to a professional for repair, or get a new Xbox. Usually with the older versions, not getting enough ventilation is due to the fan being placed too close to the motherboard, and the board overheats because not enough air can be drawn through. Get it exchanged if possible.
3 red light
The 3 light RROD is caused by a multitude of things. To fix it you have to know what you are doing; if you don't, I suggest either: selling it on eBay, or taking it to a professional. Even following Youtube videos you likely won't be able to fix it unless you truly understand what you're doing.
