20 Most Recent
Bosch AQUATAK 115 PLUS Pressure Washer Questions & Answers
Motor smokes
clean water filter out, not enough water coming out to cool the motor
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps.
http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at:
http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
I want to know capacity and specifications of yellow box capistor present in input supply of my Bosch aquatak 10 pressure washer?
Weight: The Aquatak 10 weighs 6000 grams, ensuring stability during use.
Maximum Pressure: Unfortunately, the specific capacity of the yellow box capacitor in the input supply is not explicitly mentioned in the available manuals. However, I recommend referring to the official user manual for detailed technical information.
Motor Power: The motor power of the Aquatak 10 is 1500 W.
Maximum Flow Rate: The maximum flow rate is 350 liters per hour.
Inlet Water Temperature: The pressure washer can handle inlet water temperatures up to 40°C.
Detergent System: It features a high-pressure foam detergent system.
Pump Type: The pump is a 3-cylinder all-metal pump.
Cable Length: The power cable is 5 meters long.
Hose Length: The hose length is also 5 meters (made of PVC).
Nozzles: It comes with a fixed fan jet nozzle.
Regarding the oil leak issue you mentioned, it's essential to address it promptly. Here are some general steps:
Turn off the pressure washer and disconnect it from the power source.
Inspect for visible damage or loose parts.
If you suspect a broken bearing, consider contacting a professional technician for assistance.
For the oil leak, I recommend not attempting to fix it yourself. Contact a qualified technician to address the problem.
Please note that the Aquatak 10 is an electric pressure washer and does not require oil replacement, as it does not have an oil reservoir. If you need further assistance, consider reaching out to Bosch's customer support or a certified tech.
3/11/2024 7:42:53 PM •
Bosch Garden
Answered
on Mar 11, 2024
How do I remove the cracked positioning lever from Bosch Rotak 34-13 lawnmower?
To remove the positioning lever from a Bosch Rotak 34-13 lawnmower, follow these steps:
- First, disconnect the lawnmower from the power supply to ensure safety.
- Locate the positioning lever on the handle of the lawnmower.
- You may need to remove the screws or bolts that are holding the positioning lever in place. Use a screwdriver or wrench as required.
- Once the screws or bolts have been removed, gently pull the positioning lever out of its slot.
- If the positioning lever is still stuck, you can use a flat-head screwdriver to gently pry it loose.
- Once the old positioning lever has been removed, clean the area thoroughly and remove any debris or dirt that may be present.
- Now you can install the new positioning lever by sliding it into the slot and securing it in place with screws or bolts.
- Finally, reconnect the lawnmower to the power supply and test the positioning lever to ensure it is working properly.
If you are unsure about any of the steps or do not have the proper tools, it is recommended to consult a professional for assistance.
3/3/2023 11:35:36 AM •
Bosch Garden
Answered
on Mar 03, 2023
Bosch fridge freezer alarm constantly going off.
The constant beeping could be due to a malfunction or error in the appliance. The first step is to consult the user manual for troubleshooting steps or error codes that might help diagnose the issue. If the manual does not provide a solution, it may be necessary to contact a professional technician for repair.
2/8/2023 6:27:37 PM •
Bosch Garden
Answered
on Feb 08, 2023
