20 Most Recent
JBL Encounter 2.1 Computer Speakers Questions & Answers
How to open the subwoofer unit?
particular model may please be mentioned.
In general, there is two types of packaging
1. The bottom or the back or the front will have screws, you can unscrew and that's it.
2. Some sub-woofers are factory sealed, that means all their panels are glued shut. Now here's the problematic part. Usually you can't open a glued shut sub-woofer without inflicting some cosmetic damage. You may put scratches on it or vice versa.
Still if it is very essential, you may have to use some thin and flat object like a praying knife or a flat head screwdriver. Use them with caution as applying too much pressure at wrong angels may result into ricocheting into your hand / fingers.
I have jbl encounter speaker,
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
I can not increase or
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Have a JBL Encounter
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
My son threw some coins
Subwoofers are accesible only requirng the tools and knowhow processes to dismantle. Observe the bolt straps on the woofer device from which to determine what type of tools are required. Gathering the entire components of tools that would beome useful is required, or attaining a tool box is prior preparation. Woofer s depeding on the location with a vehicle makes accessible. For example, woofers that are within an interior of vehicles require ascertaining the methods of gaining accessibility to perform modifations. Woofers placed in vehicles usualy are emebeded within box containers as sound replication requirement or as means to place within the vehicle without disintegrity.
Sound is low and garbled
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
