20 Most Recent
Remington 16" Electric Chainsaw Questions & Answers
My Remington electric chainsaw will not start
The switch has failed or you broke contact in the plug. Replace the saw and use it only under light load on dried wood only . It isn't designs for heavy use or wet wood the drag overheat the switch and stress stretches the chain and adjuster enough to create failure within the first couple days of use.
Remington 4620 fuel line diagram
Check this out https://www.google.com/search?q=Remington+4620+fuel+line+diagram&rlz=1C1ASUM_enPH918PH918&source=lnms&tbm=isch&sa=X&ved=2ahUKEwi1mr7S-s72AhXSsVYBHUBpCcMQ_AUoAXoECAEQAw&biw=1517&bih=736&dpr=0.9
I have a older remington gas powered chainsaw
An impulse line from the crankcase pressurizes the oil tank to force oil to the chain. On the bottom of this line in the oil tank is duck (one way) valve. I think it has failed (open) and you are sucking bar oil into the crankcase. Loosen the oil cap before putting her to bed to help stop the bar oil from weeping. Key word Help. LOL HTH
Lou
If this doesn't solve your problem try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Do a search for your saw it has probably been asked and answered. They will help if my suggestion doesn't work and you can't find an answer.
