20 Most Recent
Cakewalk Project 5 Workstation (cakp51) Questions & Answers
Import problem
the first thing I suggest you find out is if project 5.2 allows you to import the file from fuity loops 8 in the source format. keep in mind that as versions get upgraded backwards compatability inter-vendor compatability or format compatability in genera may be compromised along the way.
I would suggest to try to save your file from fruity loops 8 in another format that may be compatible with project 5.2 or simple save the same file in all formats avaliable and try one by one in project 5.2 and see if you get the file to play properly.
good luck!
No signal coming through from
The new version of cakewalk is not compatible with your computer. Can you go back to a previous version that worked for you?
8/8/2010 6:37:48 AM •
Cakewalk...
Answered
on Aug 08, 2010
I just baught a new
Hello
Music creator 3, was made to be used with windows xp, you might want to try right clicking on the shortcut and try running it as administrator, and also if that doesn't help, right click and properties, find the
compatibility page and set it to windows Xp Service pack 3 or similar.
If the program still keeps crashing, it might be best to upgrade to Music Creator 5 which is windows 7 friendly.
http://www.cakewalk.com/products/musiccreator/
1/18/2010 7:16:24 PM •
Cakewalk...
Answered
on Jan 18, 2010
I have sonar 6 le[cakewalk.been recoding for moths
I have tried using different program for recording. It does work for some time but time came when I have also problem met with it. So I uninstall it after clearing all folders etc in program files and in Control Panel, I tried to re install it. PRESTO! it worked with that fine.
Try unistalling if you have the isntaller with you and the Key product.
TNKS
6/21/2009 4:42:16 PM •
Cakewalk...
Answered
on Jun 21, 2009
