20 Most Recent
Hamilton Beach Hb-P90d23al-Dj Microwave Ovens Questions & Answers
How do I silence the beep on my hamilton beach microwave
If you live in a place where using your microwave in your own apartment angers other tenants, I say time to move, if it is your roommates, then be next to unit and open when at 1...
Otherwise pulling apart to shunt or cover speaker may damage the unit and since you asked here, you likely are not electronic savvy and I would not recommend you learn working on such a dangerous device...
Silence a hamilton beach microwave. How to
Tips to Silence Hamilton Beach Microwave includes cleaning the interior, placing the microwave on a stable surface, using microwave-safe dishes and containers, repositioning the microwave in an open area with ample ventilation, checking for loose parts, using lower power settings, investing in noise-canceling mats, and checking the exhaust fan. To adjust power settings, start the microwave by pressing the "Start" or "Time Cook" button, ensure the microwave is placed on a level surface, and avoid enclosed spaces. Regular maintenance prevents loose or damaged parts.
Source: How to Silence Hamilton Beach Microwave
Turntable spigget arced & burned black even after wire brush cleaning arcing occurred on Hamilton beach microwave
If the turntable spigot on your Hamilton Beach microwave has arced and burned even after cleaning it with a wire brush, it indicates a potential issue with the electrical connection or the turntable motor. Here are a few steps you can take to address the problem:
- Disconnect Power: Before proceeding with any repairs, ensure that the microwave is completely disconnected from the power source to avoid any risk of electric shock.
- Inspect the Turntable Spigot: Carefully examine the turntable spigot for any signs of damage, such as burn marks or melted plastic. If the spigot is severely damaged, it may need to be replaced. Contact Hamilton Beach customer support or a qualified technician to inquire about replacement parts and proper installation.
- Check the Wiring: Inspect the wiring connections near the turntable motor for any loose, frayed, or damaged wires. If you notice any issues, they should be repaired or replaced by a professional technician to ensure safe operation.
- Test the Turntable Motor: The turntable motor may be faulty and causing the arcing issue. To test the motor, you will need a multimeter to check for continuity and proper functioning. However, this requires electrical knowledge and experience, so it's best to consult a qualified technician for assistance.
- Seek Professional Assistance: If the arcing issue persists after performing the above steps, it is recommended to contact Hamilton Beach customer support or a professional technician. They will have the expertise to diagnose the problem accurately and perform any necessary repairs or replacements.
