20 Most Recent GNC On-The-Go Blender - Black Questions & Answers
Need a gasket for gnc on the go live well blender model # -HL-2574
Did you get any answers? I need a gasket for my HL-2571, Made by Home Life solutions. I've written them and have not heard back. http://www.homelifesolutionsinc.com/contact/
4/4/2019 11:06:42 PM • GNC On-The-Go... • Answered on Apr 04, 2019
Can I get a new gasket for a GNC on the go blender
Yes, you can order the replacement rubber gasket seal ring from nutri Bullet 600w or 900w which is the same size on ebay for $1.00.
4/4/2019 11:03:50 PM • GNC On-The-Go... • Answered on Apr 04, 2019
2answers
Need a gasket model-hl-2574
call 1-800-645-3867. M-F. 8a-5p (est)
3/15/2018 4:41:29 PM • GNC On-The-Go... • Answered on Mar 15, 2018
0answers
Motor stopped running. Is there a thermal reset or
Replace motor.
12/30/2013 12:09:30 AM • GNC On-The-Go... • Answered on Dec 30, 2013
0answers
Does not run
Be the first to answer 10/10/2013 8:14:57 PM • GNC On-The-Go... • Posted on Oct 10, 2013Be the first to answer
0answers
0answers
Durabrand Blender TSK-9368AP. How can I get a replacement pitcher for my TSK-9368AP blender?
Jimmy LavinderYou are tagging a dormant unanswered post that is 10 years old!The section up at the top is for you to ASK the Original Poster a QUESTION before giving him an ANSWER. You can't get any parts for anything online without an email address and a physical address. These parts are never found in a store. Durabrand is a cheap company of the 'sell and run' variety. There are no spares.https://www.google.com/search?q=durabrand+TSK-9368AP+partsDump it and buy a Vitamix, a company that guarantees spares forever or even a Braun, or Oster that guarantees them for 10 years...
4/8/2024 12:18:36 AM • Blenders • Answered on Apr 08, 2024
Breville Antony Worrall Thompson BL3 Blender user manual
Olabisi. It is better to create your own question rather than tagging a 13 year old question in the area where you ask the OP for further information before committing to an answer. Stir function runs the blades at a much slower speed to incorporate ingredients slowly. https://www.kitchenaid.com/pinch-of-help... STIR. To stir ingredients in a blender, start with a low, slow speed and gradually increase it to a medium speed. Blend until ingredients are completely combined. Different Blender Settings and What They Do - KitchenAid ..
3/26/2024 4:25:22 AM • Blenders • Answered on Mar 26, 2024
I have a Waring WSB33 stick blender blade does not turn
Actually I do repair these stick types all of the time. The trick is getting the head off. Then its a simple Process to remove the shaft and clean inside and add bearings or bushings of needed. After removing the blade and blade holder, Remove the coupling at the top, then remove the 4 screws. After that you will see a aluminum washer. Stop here. To remove the head assembly, you need to make a large slide hammer like a split bearing. Lead or steel is good. Or a circle of cement 8 inches in Diameter and 4 inches thick. The inside hole should be as close to the diameter of the mixer shaft as possible. Cast it in two halves so when assembled it forms a ring around the shaft. Wrap this with lots of duct tape. also place a ring of duct tape around the plastic head where the cement will touch it. now wearing gloves, grab the metal base (or secure it to something with a chain or in the fork of a tree). Once secured, slide the weight quickly against the plastic head assembly. After a few hits the head should pop out. Then remove the shaft, replace the o-rungs in the center bearing, clean the unit & reassemble.Use Silicone as sealant when reassembling the body. There is no need to remove the lower seal assembly but clean it with a small bottle brush. I have included pictures of this procedure but im too ugly to make a You Tube Video. ;) These pictures are from my teaching tool and were cut to show anatomy. Theseafox Enterprises cimg5933-v4qv1bmfzokhu3d0grjs2y1r-d-0.jpg cimg5936-v4qv1bmfzokhu3d0grjs2y1r-d-1.jpg cimg5932-v4qv1bmfzokhu3d0grjs2y1r-d-2.jpg
3/20/2024 3:32:45 AM • Blenders • Answered on Mar 20, 2024
Prolectrix Soup Maker. My soup maker didn't heat the soup up?
Question edited for clarity. That is likely a failed heating element, failed thermostat, or worse case scenario, a failed control board. https://www.google.com/search?q=prolectrix+soup+maker+not+heating+up ..
2/6/2024 9:16:54 PM • Blenders • Answered on Feb 06, 2024
My B and D BL5000 blender doesn't stop when I press the STOP button. The motor goes when the cord is plugged in. Is this repairable? How? I have looked at the screws to get at it
the lock/unlock button on the Cuisinart Smart Stick CSB-75 blender may not stay locked when pressed in. The solution is to hold the blender in the palm of your dominant hand, press the low or high button and hold, then push and release the lock button on top with a finger on your other hand. The blender motor should start as soon as you push the lock button down and stay running until you release the high or low button. However, fix.com offers OEM Black and Decker blender parts and accessories, including rubber gaskets, jar bases, measuring cup lid inserts, and blade assemblies. You may want to check if the parts you need are available and replaceable. If you are unable to repair the blender yourself, you can contact Black and Decker customer service for assistance. They may be able to provide you with additional information on how to repair your blender or direct you to a local repair shop.
1/26/2024 4:05:54 AM • Blenders • Answered on Jan 26, 2024
Can I get a picture of the wiring I have Listed Type M 133. 734 Z Bamix. Took the top off and 1 wire was off
Send it back under the lifetime warranty on the motor. The motor is not working, right? https://www.google.com/search?q=bamix+blender+warranty ..
1/25/2024 6:07:33 AM • Blenders • Answered on Jan 25, 2024
GNC On-The-Go Blender - Black Logo
18 questions posted
Top GNC Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a GNC Blender Expert? Answer questions, earn points and help others
View Most Popular
GNC Blenders
  • GNC Blenders
Most Popular Question
get new gasket gnc go blender
  • Blenders
