20 Most Recent Wascomat Parts Wascomat 986918 Washer BURNER,TD75 GAS 54KW - Wascomat Laundry Part Questions & Answers
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard: First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer. Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off). If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
11/2/2015 5:38:58 PM • Wascomat Parts... • Answered on Nov 02, 2015
Wascomat 16n4 front of drawer broke off. how can
I have a Wascomat W655CO,This morning I got a screen message, Wait doors is locked?I waited but the door never unlocked?
10/28/2013 12:23:13 PM • Wascomat Parts... • Answered on Oct 28, 2013
Need programming manual for wascomat w655co
Got a Wascomat W655CO and I got a screen message, Wait door is lockedDoor never unlocked?
10/28/2013 12:21:21 PM • Wascomat Parts... • Answered on Oct 28, 2013
0answers
CH slider on potterton programmer ep2002 broken can I get a spare or do I need a new programmer?
If you're looking for a direct replacement for the broken slider, you might be in luck. The Potterton EP2 Programmer is now the official replacement for the EP20021. It's designed to fit the existing backplate without any rewiring, provided the backplate is undamaged and in good condition. EP2 replacement programmer for EP2002 (plumbersforums.net) The EP2 doesn't have the additional terminals that the EP2002 had (which allowed it to function as a mini-wiring center), but the core wiring should match. So, if your EP2002 was acting as a wiring center, you might need to check if the EP2 accommodates all your existing wires. Considerations: Since you're controlling your central heating (CH) via a Netatmo 'smart' thermostat and manually managing hot water (HW), the EP2 might suit your needs. The CH slider permanently on and HW controlled separately aligns with your current setup. Keep in mind that the EP2 doesn't have the extra features of the EP2002, so assess whether those additional terminals were crucial for your system. Installation: Replacing the programmer involves turning off the power, unscrewing the old one, and attaching the new EP2 to the existing backplate. Remember to reuse the little red 'LED' cover from your old programmer3. If you're comfortable with basic soldering, you could also replace the tiny NiCad battery inside the EP2002 to see if that resolves any issues. Budget-Friendly Option: While the EP2 typically costs around £65-70, you might find a better deal on platforms like eBay3. Just ensure it's compatible with your existing setup. Remember to turn off the power before any installation work.
4/22/2024 5:12:55 PM • Washing Machines • Answered 22 hours ago
Tecno front load washing machine model : TN-312 E01 Error Code problem
Ttypically indicates a problem with the water supply. Troubleshooting: Clogged Inlet Valve: The inlet valve controls the water flow into the machine. If it becomes clogged, the machine won't fill with water, resulting in the E1 error. To address this: Turn off the washer and unplug it. Remove any debris blocking the inlet valve. Brush it with distilled white vinegar. Reattach the water valves and turn on the power to the washer. If the issue persists, consider replacing the inlet valve. Failed Inlet Valve: If the inlet valve has failed, it needs replacement. Check for water leaks to identify a failed inlet valve. Pressure Switch Hose: A damaged or clogged pressure switch hose can also trigger the E1 error. Follow instructions to clean the pressure switch hose. Water Level Sensor: The water level sensor detects water levels in the machine. If it's malfunctioning, the E1 error may appear. Test the sensor using a multimeter after unplugging the machine and removing the control panel. Note the divergent possibilities below. Because of this, you may have to seek professional assistance. https://theportablelaundry.com/how-to-fix-the-e1-error-on-washing-machine/ Understanding E01 Error: What Does E01 Mean on a Washing Machine? - Washing Machine Blog
4/20/2024 9:37:09 PM • Washing Machines • Answered 2 days ago
Defy twin tub 1300 brake cable snapped
Confirm the cable snapped. Replace the cable if so. You can check the owner's manual or contact Defy service centers for the correct part. New Defy Customer Service number is : +912269181919 Install the new cable by following the reverse steps of removal. Make sure it's securely attached. After replacing the cable, test the machine by running a wash cycle to ensure that the brake engages and disengages properly. If everything works as expected, you've successfully fixed the issue. https://www.manualslib.com/manual/2077795/Defy-Twinmaid-1300.html
4/20/2024 9:28:08 PM • Washing Machines • Answered 2 days ago
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0". If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
4/19/2024 3:06:17 AM • Washing Machines • Answered on Apr 19, 2024
Balance systems or shocks broken. GE Spacemaker has broken stabilizers.
GE Spacemaker is a generic range of appliances. All questions in Fixya need full 'make model (what it is)', first 3 words. If the stabilizers are broken Google for parts. GE (numerical model number) Parts https://www.google.com/search?q=GE+spacemaker+parts Depending on age, they may no longer be available ..
4/15/2024 7:28:59 PM • Washing Machines • Answered on Apr 15, 2024
Dear sir, I have Primus MB205 washer extractor problem. It shows error out of order, ask for service (error 301: mits 0c2)
Question edited for spelling. You will have to do what it says and call for service. This is a Commercial Machine and not popular in North America where we are. https://www.google.com/search?q=primus+mb205+washing+machine The error is not listed anywhere https://www.google.com/search?q=error+301+mits+0c2 ..
4/14/2024 5:20:05 PM • Washing Machines • Answered on Apr 14, 2024
WASHER EXTRACTOR PRIMUS MB205 OUT OF ORDER SHOW ASK FOR SERVICE ERROR 301 MITS. 0C2
Code 301 relates to a drain failure. The rest of the code may relate to specific parts. I find no explanation available for the remainer of the code. It is likely only the manufacturer can say what that refers to. https://primuslaundry.com/en/contact
4/14/2024 11:12:07 AM • Washing Machines • Answered on Apr 14, 2024
Lay out of water tubes. I have taken apart but forgotten the layout DDS04 E01
See page 13 of the user manual. screenshot 2024-04-14 at 10.54.12-undefined-undefined-0.png
4/14/2024 9:55:10 AM • Washing Machines • Answered on Apr 14, 2024
2answers
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error. Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract. If the fan is working then it's probably an inverter.
4/10/2024 5:59:51 PM • Washing Machines • Answered on Apr 10, 2024
Hayward 250 HD. Control panel does not display the temperature.
I am sure I answered this yesterday? You posted to washing machines category and this appears to be a gas fueled pool heater. You would be best contacting a service engineer because it is gas powered, although if it does blow up, it is outside or will only blow up the pool house.
Universal H-Series Natural Gas 250000 BTU Low NOx
Hayward Pool Products https://hayward.com > universal-h-series-natural-gas-250... Universal H-Series Natural Gas 250,000 BTU Low NOx. Hayward. SKU: W3H250FDN. Service and diagnostics manuals https://www.google.com/search?q=hayward+250+hd+service+manual ..
4/9/2024 5:23:09 AM • Washing Machines • Answered on Apr 09, 2024
2answers
Installing transit bolts
advise you take the top off so you can see where the bolts locate
4/7/2024 9:51:13 PM • Washing Machines • Answered on Apr 07, 2024
Wascomat Parts Wascomat 986918 Washer BURNER,TD75 GAS 54KW - Wascomat Laundry Part Logo
Popular Tags
1 questions posted
Top Wascomat Parts Washing Machines Experts
john h
Are you a Wascomat Parts Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Wascomat Parts Washing Machines
Most Popular Question
dryer shows error 8 overheating in or
  • Washing Machines
