20 Most Recent
Magimix 5150 Food Processor Questions & Answers
The metal blade does not reach the bottom of the bowl
I am confused by this too! I have a brand new magimix 5200 and all my blades sit about 2 centimetres above the bottom of the bowl resulting in nothing being mixed below them. Very annoyed after spending $700 on this thing!!!
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
If your Magimix food processor won't turn on despite the handle clicking in, there may be a problem with the power supply or the motor of the device. Here are a few troubleshooting steps you can try:
- Check that the power cord is securely plugged into an outlet and the processor's base.
- Make sure the outlet is working by plugging in another device.
- If the outlet is fine, then try plugging the Magimix into a different outlet.
- If the device still doesn't turn on, it's possible that the motor has overheated. Allow the device to cool down for a few hours and try turning it on again.
- If none of these steps work, you may need to contact the manufacturer or a repair technician for further assistance.
It's also worth noting that the Magimix 3200XL comes with a 30-year motor guarantee, so if the motor is the problem and the device is still under warranty, you may be eligible for a replacement.
How do I remove the blade unit from Magimix cuisine 5100?
Firstly, press the STOP button. Then turn the lid in a clockwise direction and lift-off. Carefully remove the blade and inner bowl/bowls (depending on what combination you are using). Finally turn the main bowl clockwise to unlock it from the motor unit and lift off.
