20 Most Recent
Sony PlayStation® 3 (80GB) Console Questions & Answers
Need help!! Trying to play a movie on my PS3.
Since it says u hav 2 update the system to renew the encryption key, then update the system lol
go to settings then system update and it will update it to the latest firmware or u can dload it from the playstation website, this will probably solve ur problem :D
ohh and just to clarify sumthin...what type of movie r u playing, a dvd? and if so is it PAL or NTSC. if u hav a PAL ps3 and u are trying to play an NTSC movie on it, then sadly it wont work...
hope this helps! :D
9/25/2018 9:20:48 AM •
Sony...
Answered
on Sep 25, 2018
Will playstation 3 play blu ray movies off usb
the PlayStation 3 can read just about any usb memory stick and play can movies from them, since a usb's bandwidth is significantly lower then the ps3 hard drive it's recommend to copy the movie to the ps3's hard drive.
also it matters how the movie was converted. some converted movies wont play on the ps3 no matter what codec your using to encode the movie with.
6/4/2018 5:49:44 AM •
Sony...
Answered
on Jun 04, 2018
How can I correct 80710092 error?
The 80710092 error means that you have an issue connecting online to the PlayStation Network.
It could be caused by scheduled maintenance or issues with your internet connection
To fix it follow these steps:
1. Turn off your PS3, your router, your modem, etc.
2. Let everything stay turned off for at least one minute.
3. Turn on you router/modem and wait for full power up (about two minutes and after all the lights are back on)
4. Turn on your PS3 and try to access PSN
If the problem persists, check the status of the Playstation Network.
4/25/2016 7:29:33 PM •
Sony...
Answered
on Apr 25, 2016
How can I stop my ps3 from freezing when it is rebuilding the file system. It loads and then goes black on the screen.
Jimmy, there are only a few reasons why your system is freezing up. I'll go down the list and you can double check to see if one or more of these might be the issue. 1) Do you have enough space on your Hard Drive (HDD) 2) Good internet connection. 3)Corrupt files/incorrect file name uploading from USB stick. 4) Are you running a "Jail Broken" PS3? One or more of these could cause your system to refuse rebuilding the files. You may have to restore the system to factory settings and install the latest firmware. Good luck, hope this helps.
12/3/2015 12:55:20 PM •
Sony...
Answered
on Dec 03, 2015
Why won't my netflix for ps3 let me sign in?
Typically, this issue is resolved by logging into Netflix via PC and making sure the log in information matches the info on the PS3. Also, be aware that the standard package for Netflix allows only 2 devices to access Netflix from 1 account at the same time. For example, if you are watching Netflix on your PC in 1 room, and someone is watching it on a PS3, then you won't be able to access it from a Smart Phone or other devise, until 1 is disconnected from Netflix.
g" alt="11276523-pegq3jcpeyammqgc4cyp0cpv-4-0.png">
9/14/2015 4:35:00 PM •
Sony...
Answered
on Sep 14, 2015
