20 Most Recent Stairmaster Nautilus SM916 Stepmill - Refurbished Questions & Answers
WHEN USING IT RANDOMLY IT SPEEDS UP
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH I would suggest starting by checking the alternator brushes. The following link will show you how to do this. Stairmaster Alternator Brush Replacement Video
6/27/2016 9:30:14 PM • Stairmaster... • Answered on Jun 27, 2016
Stannah Saxon 300 stairlift armrest to footrest cable replacement
Direct from Stannah for 40 quid!
Footrest to Arm Cable - Stannah Saxon 300/400/420
Stairlift Spares https://www.stairlift-spares.co.uk > shop > product > fo... Footrest to Arm Cable for the Model 300/400/420 Stannah Stairlift with Saxon seat. All orders are dispatched by Courier. £39.95
3/27/2024 5:27:39 AM • Stairmaster... • Answered on Mar 27, 2024
My Stairmaster will not increase speed until level 8. Is this normal?
Typically, the stair master should gradually increase in speed from lower levels. If it's not speeding up until level 8, there might be a malfunction. It could be a setting or technical issue. Have you checked the manual or contacted customer support?
12/5/2023 3:46:33 PM • Stairmaster... • Answered on Dec 05, 2023
2answers
Stairmaster stair mill. It won't run when a light person less than 110 lbs is on it but when I am on it 160 lbs - its just fine
Hi, please increase the steepness of the floor of the machine to start. If this does not work, then your partner might start off each use of the machine by adding a small textbook to the floor to overcome the issue and allow the book to slide of as the treadmill moves. From there on as long as she's moving the treadmill should continue to function. In the mean time, you can schedule servicing on the machine to recalibrate it. Thank you.
11/26/2022 4:55:24 PM • Stairmaster... • Answered on Nov 26, 2022
Replacement battery for stairmaster 4400pt
amazon or sportsmith Haywood
9/29/2022 3:28:01 PM • Stairmaster... • Answered on Sep 29, 2022
How to reprogram scrolling message board on stairmaster 4000pt
The first link appears to have the information. The manual is in the link as well. https://www.google.com/search?q=change+the+scrolling+message+on+a+used+stairmaster+4000pt ..
4/29/2022 3:45:57 AM • Stairmaster... • Answered on Apr 29, 2022
Stepmill stairmaster 5000PT can be programmed but then when you hit Start it does nothing.
This could be so many things. I’d recommend searching YouTube, there are some good videos on this issue
7/13/2019 5:17:54 AM • Stairmaster... • Answered on Jul 13, 2019
Stannah 420 stops randomly anywhere on the staircase and beeps
move you out of computer repair stair elevators are not a topic here, at all. but did you read the manual first or call of their assistance? it even works on power outages(has battery) it has 350lb max load, so using it to carry huge packages will fail. if over that limit. https://www.stannah-stairlifts.com/resources/stairlift-user-manuals/ better this, page. read this yet, 3rd google hit. https://www.stannah-stairlifts.com/technical-assistance/
7/5/2019 5:42:25 PM • Stairmaster... • Answered on Jul 05, 2019
I have a Stairmaster 4000 PT. Both pedals sank simultaneously while I was on it and went limp as if the chain broke, but it didn't. Is there a common cause? Haven't opened up casing yet.
There are several potential causes. One is that the clutch mechanism that allows the steps to 'pump' the flywheel has suffered an internal failure, possibly a sprag failure; another is that the drive from the clutch to the resistance has broken (I don't recall if that is a chain or belt on the 4000) Rather than troubleshoot from distant memory, here's a link to the service manual: https://www.manualslib.com/products/Stairmaster-4000-Pt-Series-3234686.html
4/11/2019 12:46:03 AM • Stairmaster... • Answered on Apr 11, 2019
Stairmaster Nautilus SM916 Stepmill - Refurbished Logo
2 questions posted
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Stairmaster Exercise & Fitness
Most Popular Question
when using randomly speeds up
  • Exercise & Fitness
