20 Most Recent LG GSA-T20N DVD±RW Dual Layer Burner Questions & Answers
Latest Firmware for HL-DT-ST DVDRAM GSA-T20N DVD-Drive
Try to install automatic Firmware Uploadre
Download Here - http://uk.lge.com/support/download_soft.jsp
Its from LG Official Site so its safe
9/20/2017 5:44:33 AM • LG GSA-T20N... • Answered on Sep 20, 2017
Amilo PA 2548: DVDRW GSA-T20N can't write discs
Go into device manager and delete that disk drive and then reboot and it should reinstall it. That will separate the drivers and put the old one back.
6/10/2017 10:25:30 PM • LG GSA-T20N... • Answered on Jun 10, 2017
GSA-E60N need driver for ubuntu linux
No driver required. Linux will use a built in universal driver.
4/24/2014 6:56:28 PM • LG GSA-T20N... • Answered on Apr 24, 2014
0answers
Do nor turn on
Be the first to answer 8/30/2012 2:47:10 AM • LG GSA-T20N... • Posted on Aug 30, 2012Be the first to answer
0answers
Dvd drive(HL-DT-ST DVDRAM GSA-T20N ATA
Firmware for HL-DT-ST DVDRAM GSA-T20N is here:http://files.rpc1.org/index.php?act=category&id=468
8/14/2012 8:31:51 AM • LG GSA-T20N... • Answered on Aug 14, 2012
0answers
Error Code: 1004 CDB: 2A 00
Checkout the solutions on this forum:
http://forums.techarena.in/xp-hardware/647582.htm
6/28/2011 8:50:09 AM • LG GSA-T20N... • Answered on Jun 28, 2011
My computer has given me
until you no exactly what has caused the problem you cant fix click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files you could run the check disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart or you could download a registry cleaner also click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
1/29/2011 3:20:03 PM • LG GSA-T20N... • Answered on Jan 29, 2011
Windows cannot load the device
I cant understand what device (laptop/desktop)you are using.
So i will try to present, desktop or the laptop also.
Click on the link
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
And clink on RUN NOW from right side box
It will fix your problem.
It could be a problem with the lens, you shouldtry cleaning the lens, it's already gone bad there is no harm in trying. If you take a little risk can solve.Follow the instruction: Don't panic it's very simply.
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. now you can fit to your pc
  4. If it does the same problemplease change the cd/dvd rw because the lance has defected.
  5. HOW TO REPLACE CD ROM e.g. follow link=http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=&cc=us&lang=&product=242024
For Laptop http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
Hope it will help you.
1/26/2011 3:09:47 PM • LG GSA-T20N... • Answered on Jan 26, 2011
Driver for GSA_T20N
HI, GO THROUGH THE LINK .
HERE YOU CAN DOWNLOAD DRIVER FOR GSA_T20N.
http://www.topshareware.com/gsa-t20n-driver/downloads/1.htm
GOODLUCK
1/19/2011 9:11:06 PM • LG GSA-T20N... • Answered on Jan 19, 2011
I NEED FIRMWARE FOR GSA-T20N MERCI
try here for it http://www.motherboard.cz/cdrom/lg.htm I’m happy to help further over the phone at https://www.6ya.com/expert/troy_d840d2702258460c
10/16/2010 9:15:04 PM • LG GSA-T20N... • Answered on Oct 16, 2010
3answers
TO DOWNLOAD DRIVERS FOR LG GSA-T40N MULTI DVD
Windows XP/Vista/7 should automatically use its own drivers, so that you can read from CD/DVD disks.
You'll need "extra" software if you want to play a DVD-movie, or if you want to write CD/DVD disks,
e.g., 'PowerDVD' to "play", and Nero Burning to "write".
6/23/2010 6:31:52 PM • LG GSA-T20N... • Answered on Jun 23, 2010
MY pc was didnt detect dvd
go to registry editor and delete upper and lower filters
3/26/2010 11:43:28 AM • LG GSA-T20N... • Answered on Mar 26, 2010
My Optical Drive will not boot from Bootable Disks
Follow the link below to boot your CD's in optical drive.
http://pcsupport.about.com/od/tipstricks/ht/bootcddvd.htm
12/20/2009 11:33:31 AM • LG GSA-T20N... • Answered on Dec 20, 2009
Hl-dt-st rw/dvd gcc-4240n not working
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
11/27/2009 5:12:06 AM • LG GSA-T20N... • Answered on Nov 27, 2009
My disk drive doesn't detect burning media.
You MUST have software that is for burning a CD.
Some examples are "CD Creator", "Nero" and others.
These programs are OFTEN not included and MUST be purchased seperately.
10/21/2009 3:33:26 AM • LG GSA-T20N... • Answered on Oct 21, 2009
LG GSA-T20N DVD±RW Dual Layer Burner Logo
35 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
latest firmware hl dt st dvdram gsa t20n
  • Computers & Internet
