20 Most Recent JBL PB10 Subwoofer Questions & Answers
2answers
JBL pb 10 sub keeps going into standby mode
replace C42. easy fix. ordered the new capacitor from amazon (100uf 35v)
12/16/2021 2:39:57 AM • JBL PB10... • Answered on Dec 16, 2021
2answers
My jbl pb 10 has a noise and it burn the fuse...
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
5/25/2021 1:50:02 AM • JBL PB10... • Answered on May 25, 2021
My JBL PB10 lights up
As long as its not blowing the fuse it can be saved - look for Edwards Electronics - Ebay - We fix them . Thanks.
5/25/2021 1:47:26 AM • JBL PB10... • Answered on May 25, 2021
4answers
JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
2/10/2018 8:11:10 PM • JBL PB10... • Answered on Feb 10, 2018
Jbl sub makes ear splitting noise when plugged into any ac outlet
I have the same problem with my Creative Labs Sub-woofer, which I plan to strip and inspect, as I do electronics. I've read elsewhere that a faulty capacitor can cause this motor-boating screech. If your sub can be opened, unplug and look for bulging caps. The silver top should be flat. Rounded top usually indicates a blown cap. Meanwhile, I bought another surround setup, by Logitech.
1/31/2018 11:59:10 PM • JBL PB10... • Answered on Jan 31, 2018
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried! The 158 amp is totally unsuitable for the JBL. This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel 8 Ohm.
6/2/2017 1:39:26 AM • JBL PB10... • Answered on Jun 02, 2017
0answers
Wiring questions
Be the first to answer 3/10/2014 4:13:23 AM • JBL PB10... • Posted on Mar 10, 2014Be the first to answer
manual
0answers
Hand amp fuse blown
you can change the fuse or wrap it with aluminum foil
3/28/2013 11:44:54 PM • JBL PB10... • Answered on Mar 28, 2013
Blinking signal, sound
Hi my name is MIchael and I repair the following amps JBL PB10, PB12 If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR PB10 PB12 - you will find us ... Edwards Electronics ....
5/24/2012 2:48:01 AM • JBL PB10... • Answered on May 24, 2012
0answers
10 pb jbl
Be the first to answer 5/15/2012 4:13:20 AM • JBL PB10... • Posted on May 15, 2012Be the first to answer
My pb10 subwoofer makes a
Item can be fixed - ship it to Edwards Electronics - Look For US On Ebay - Thanks
1/2/2012 8:32:59 PM • JBL PB10... • Answered on Jan 02, 2012
JBL PB10 Subwoofer Logo
69 questions posted
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Audio Players & Recorders
Most Popular Question
jbl pb 10 sub keeps going into standby
  • Audio Players & Recorders
