20 Most Recent PANDIGITAL (DPF802) Digital Picture Frame Questions & Answers
2answers
Shrinking picture file sizes
Use image editing software to reduce the physical dimensions, and the resolution, to decrease the file size.
2/9/2018 10:49:33 AM • PANDIGITAL... • Answered on Feb 09, 2018
SD Memory Card in frame-no pictures
1st: Make sure the SD card is in working order and not damaged. 2nd: Make sure you're using the right file type (.jpg, .png, .gif, etc) and size.
1/14/2018 7:40:49 PM • PANDIGITAL... • Answered on Jan 14, 2018
Trouble playing video on Pandigital picture frame
Have you looked in the manual to ascertain which movie formats and sizes are supported by your equipment ?
10/14/2017 12:55:35 PM • PANDIGITAL... • Answered on Oct 14, 2017
Black screen when turned on
Try recharging it, if you have a cord to plug in the wall or a usb cord to your computer, it should work as well. I hope this helps.
9/11/2016 12:47:19 AM • PANDIGITAL... • Answered on Sep 11, 2016
2answers
We need to replaace a lost 120v power cord which reduces to 9v, amp or watts unknown. We need to learn output requirements and where to shop.
Be careful or you could burn your house down. Call an electrician to avoid that unfortunate outcome.
6/7/2016 10:35:53 AM • PANDIGITAL... • Answered on Jun 07, 2016
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
10/26/2015 5:48:41 PM • PANDIGITAL... • Answered on Oct 26, 2015
0answers
My DPFmate wont charge. I tried to turn it on
Same problem here. Did you find a solution?
10/13/2015 1:39:03 PM • PANDIGITAL... • Answered on Oct 13, 2015
I have tried everything putting pics on my frame I tried the SD/MMC,USB, and nothing is working it's not communicating
Pandigital DPF80 2 Manuals Here is the user manual, hopefully this will help walk you through the steps.
9/4/2015 2:19:10 AM • PANDIGITAL... • Answered on Sep 04, 2015
0answers
WHERE CAN I GET SERVICE ON A MODEL DPF15K DIGITAL PICTURE FRAME?
i have had the same problem and i have resolved the problem as following : - measure the output tension on the external power unit ... she must be 12v ... on my unit i had 10v!!! - open it (it's difficult but not impossible) ... look at the 2 condensers 1000uF 16v ... change them and you will retrevie the 12v output and your frame picture. - an another solution is to buy a another 12v-3A external unit
4/1/2014 8:47:53 PM • PANDIGITAL... • Answered on Apr 01, 2014
0answers
Display problem
Be the first to answer 3/10/2014 4:59:39 AM • PANDIGITAL... • Posted on Mar 10, 2014Be the first to answer
0answers
I have a pandigital photo
Insert a fresh battery in the remote control. The battery compartment is a bit tricky on these frames. Push the small part toward the large end and slide open the drawer with a fingernail.
Make sure you don't lose a memory card in the frame. Check that you're inserting the card in the correct slot. You'll need to send the frame back to the manufacturer to get the card out.
Good Luck and have a nice day.
2/11/2014 12:21:45 AM • PANDIGITAL... • Answered on Feb 11, 2014
Picture frame is not showing any pictures
More than likely the SD card has lost your pictures and needs to be replaced
1/23/2014 6:19:41 PM • PANDIGITAL... • Answered on Jan 23, 2014
0answers
0answers
Pan8056w02t
Be the first to answer 1/14/2014 4:16:43 AM • PANDIGITAL... • Posted on Jan 14, 2014Be the first to answer
0answers
Screen flashing
Be the first to answer 11/21/2013 6:57:14 PM • PANDIGITAL... • Posted on Nov 21, 2013Be the first to answer
PANDIGITAL (DPF802) Digital Picture Frame Logo
164 questions posted
Top PANDIGITAL Photography Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
View Most Popular
  • PANDIGITAL Photography
Most Popular Question
tried everything putting pics frame
  • Photography
