20 Most Recent Westinghouse W4207 42 in. HD-Ready LCD TV Questions & Answers
0answers
I need to purchase a
many people take tv sets in for repairs and leave them there when the quote is not accepted as a consequence many repair shops have bins full of dead tvs many of which will still gave a base attached might be worth your while trolling the repair shops and see if you can beg , borrowr or pay for a base from one of them
11/25/2017 7:36:54 AM • Westinghouse... • Answered on Nov 25, 2017
Westinghouse tv
There is very little if any tactile feedback from most flat panels. Most also have more than six screws unless this is a very small <19 inch set. Look very carefully for a missed screw. In my experience the backs come off easily. Some sets require the mounting screw receivers be removed. They are usually removed with a flathead screwdriver.
7/8/2016 3:47:40 PM • Westinghouse... • Answered on Jul 08, 2016
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
9/8/2015 9:34:07 PM • Westinghouse... • Answered on Sep 08, 2015
How do i get out of pip mode
On most sets you hit the same pip button that you used to get in to get out. If that does not do it, look for an exit button. Also check with tv manual to see if set has a reset button for factory defaults. Maybe the pip button on remote is not working. To test remote place by radio on 600 on AM dial and put remote right on top of radio and hit any suspect button. U should hear a beep with each and every button. If a button pressed does not result in a beep, that part of the remote is no good.
8/27/2015 1:23:56 PM • Westinghouse... • Answered on Aug 27, 2015
Westinghouse TV picture started flickering, the next day screen went black.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
6/2/2015 12:29:38 PM • Westinghouse... • Answered on Jun 02, 2015
Westinghouse W4207 speaker has static. How do I fix it?
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
5/31/2015 5:06:04 AM • Westinghouse... • Answered on May 31, 2015
Remote does not work
Batteries? I replaced mine with a new RCA universal remote, works far better than the original MFG remote. Cost $15.
3/26/2015 3:50:43 PM • Westinghouse... • Answered on Mar 26, 2015
Westinghouse lcd
If picture is alright, check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
7/24/2014 2:35:24 AM • Westinghouse... • Answered on Jul 24, 2014
Dvd minami power supply repair fuse blow
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
6/3/2014 9:08:57 AM • Westinghouse... • Answered on Jun 03, 2014
My tv is not picking up any hdmi signals from my
The first step for this issue is to try a hard reset. Hook up the PS3 with both the Analog cable and the HDMI, set the TV to the Composite (analog) Input that you have chosen. Then, while the PS3 is off (red light), press and hold your finger on the power button for approx. 10-15 seconds until it beeps again. This will reset the PS3. After it turns back on, go through the set up steps, and after, it may tell you it has detected an HDMI connection, say yes and switch the TV to the HDMI input you hooked it up to. Click on yes before the timer ends and you should be all good.
5/4/2014 4:42:06 AM • Westinghouse... • Answered on May 04, 2014
I have sound but no
Hello
Give signal to TV with other devices. Feed it the signal from a DVD player, and see whether there is picture and sound. If it is OK; be sure that the problem is with DTV receiver. OK.
3/24/2014 9:40:59 PM • Westinghouse... • Answered on Mar 24, 2014
0answers
Westinghouse SK-32H590D disassembly manual
hi bob you can see a video on this repair on you tube,the manual can be downloaded from westinghose.com ,it may be simpler to purchase a unit off ebay and replace the whole unit ,i had to do this with a insignia 26 , dvd combo. good luck geodaws
12/9/2013 2:49:52 AM • Westinghouse... • Answered on Dec 09, 2013
Tv problems incomming
Download the user manual to this set by this link. It has all details.
12/5/2013 4:59:25 PM • Westinghouse... • Answered on Dec 05, 2013
2answers
I have a westinghouse lcd tv ltv-32w3 that no
do you have sound? what color is the screen?
11/3/2013 4:02:40 AM • Westinghouse... • Answered on Nov 03, 2013
My 42" LCD tv no longer has as bright a picture
The main power regulator board should be checked. Check all the supply voltages out from it. It will be best to contact any service technician.
9/29/2013 6:27:05 AM • Westinghouse... • Answered on Sep 29, 2013
Westinghouse W4207 42 in. HD-Ready LCD TV Logo
139 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
picture started flickering next day
  • Televison & Video
